My 302 is drinking oil like its soda pop - Ford Truck Enthusiasts Forums
Old 09-17-2011, 10:22 PM
ctaylor57 f100's Avatar
ctaylor57 f100 ctaylor57 f100 is offline
ctaylor57 f100 is starting off with a positive reputation.
I have discover a problem with my truck. My oil level is always low. I fill the oil to the proper level and a month later when I check the oil level, its low about two quarts. I guess the oil gauge is functioning ok since I upgraded from the idiot light to the actual gauge. I change the oil oil pressure sending, but my engine seems to have a thirst for oil. Can someone help me solve this issue?
Old 09-17-2011, 10:39 PM
heavyhitter 460 heavyhitter 460 is offline
heavyhitter 460 is starting off with a positive reputation.
it's a ford. every ford i've ever had from 4 cylinders to 8's has used oil. not 2 quatrs a month, though. usually 1/4 to 1/2 every three months.
Old 09-17-2011, 10:45 PM
Quote:
I'm going to do a oil change and Check it every week to see if I can accurately gauge the oil loss.
Old 09-17-2011, 10:52 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Is it leaking or burning? If you are truly burning 2 quarts a month, you'd be fogging the cars behind you like a mosquito sprayer. And if you're leaking that much, you'll have some pretty good puddles under your truck, and the whole underside of your rig will be coated in oil. When was the last time you checked/changed your PCV valve?
Old 09-17-2011, 11:03 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
That's what I was gonna say except Chev**let
Old 09-17-2011, 11:08 PM
Quote:
i agree, you'd be smoking like crazy or everything under your truck would have a thick coating of gunk if you were losing that much.
check the back bolts on your valve covers. if they're loose there will be oil on your firewall.
i've owned two fords that i bought new and they both magically made a little bit of oil disappear between changes straight off the factory floor. all my dodges have always stayed full between changes.
Old 09-17-2011, 11:56 PM
Mervy49's Avatar
Mervy49 Mervy49 is offline
Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.
My 1995 f150 with the in line 6 motor never leaked lost a drop of oil in 13 years. The beast was a good one.
Old 09-18-2011, 04:40 AM
jake08's Avatar
jake08 jake08 is offline
jake08 has a good reputation on FTE.jake08 has a good reputation on FTE.jake08 has a good reputation on FTE.
Check the valve guide rubber seals, inside the valve spring. Just a thought.
Old 09-18-2011, 05:59 AM
dawolverine's Avatar
dawolverine dawolverine is offline
dawolverine is starting off with a positive reputation.
The intake manifold gaskets are notorious on these for being badly installed as they can sometimes move out of position when the manifold is placed down. I'd check along the front and rear edges for leakage (I had this problem once - turned out to be leaking from the back seal and down the rear of the engine where I couldn't easily see it. Stripped it off and replaced it correctly with gasket maker and the problem disappeared immediately)
Old 09-18-2011, 08:36 AM
Let me back up a little. I don't have a leak or else there would be a oil stain on the driveway and my wife would be nagging me to clean it up. I checked it yesterday and it was at the low mark. I cant' remember the exact time before then, but I do remember it was at the low mark and I added two quarts of oil.
The PVC valve was installed in November of 2009, I had custom engine mounts installed, so while the engine was out, I had new timing chain and sprocket/oil pan, pump, pick up tube/valve covers/water pump/fuel pump installed as well.
I don't have smoke barreling out the exhaust. I saw a light blue cloud coming out yesterday and thought is was because I adjusted the mixing screws on the carb. That's why I'm going to have to start from scratch with a fresh oil change and keep a weekly record of the oil level. I don't drive it much, maybe once or twice a week to break up the routine. I put gas in every two week, 87 octane, should I be using a additive? What type on oil should I be using in a 37 year old engine, conventional or synthetic.
Old 09-18-2011, 08:50 AM
petey shoes petey shoes is offline
petey shoes is gaining momentum as a positive member of FTE.
what jake08 said. sounds like the valve seals. might be time to re-do those heads.
Old 09-18-2011, 09:04 AM
blue smoke is oil
Black smoke is fuel
white smoke is water/antifreeze
I just threw that out because you messed with the idle screws, and blue smoke wouldn't come from that.
Old 09-18-2011, 09:06 AM
Quote:
I was wondering if I should upgrade to aluminum heads or just have the cast iron ones rebuilt. I want to go with a set of Edelbrock SB Ford aluminum heads. My goal is th build a Edelbrock 302 engine, just need the heads and a water pump to complete the project.
Old 09-18-2011, 09:09 AM
Quote:
Originally Posted by Jeff and Nicolle View Post
blue smoke is oil
Black smoke is fuel
So I'm burning off the oil then. I guess the heads really need to be rebuilt or replaced.
Old 09-18-2011, 09:30 AM
doesn't sound like you use this all the time. personally, i would just rebuild the heads. do your homework on aluminum heads. gaskets, torque specs, metallic differences, compatibility with your system, expence. is it worth it? i wouldn't do it just for looks. (imho)
Zero oil pressure on gauge, questions. thx997303 Modular V10 (6.8l) 5 01-07-2015 12:08 AM
Another Oil gauge? 444dieselrod Ranger & B-Series 5 09-17-2009 01:31 AM
oil pressure question Daddyoisback 1987 - 1996 F150 & Larger F-Series Trucks 16 07-22-2008 11:34 PM
Low oil presure ontario ford guy 1987 - 1996 F150 & Larger F-Series Trucks 2 10-19-2005 07:28 PM
very low oil pressure rebel_ford4x4 1987 - 1996 F150 & Larger F-Series Trucks 24 10-23-2004 10:26 AM
Tags
1948, 1949, 1967, 302, drink, f150, ford, level, low, oil, oloda, pop, quarts, routes, soda, soft, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
