89 302 wont stay running
Hey guys, my much needed worktruck wont stay running. Had new tires and an allignment done at pep boys (was a good deal) had them hook up the diagnstic and said it was the egr valve. Truck ran fine but would stall after about 2-3 miles. Changed the egr, put new plugs in, ignition coil, and fuel filter. I know thats all random but they were all old had new ones in the basement for years. Truck started after a shot if either. Ran great for 4 minutes. Then started to sputter and stalled. Then wouldnt start again. I gave up. I need this truck really bad. Any ideas on what it could be? Thanks guys! Oh its a 302, sorry
Gas coming out of the fuel rail means you have some fuel pressure. Can you install a pressure gauge to see if the pressure is in the correct range (about 35-40 psig)?
The engine dying after running for a few minutes indicates that the computer is having problems going into closed-loop operation. That's usually caused by a sensor problem. Does it have a MAF sensor? Can you run a KOEO self-test on the EEC and report the codes here?
test number 2 only needs a wire and you count the flashes from the check engine light.
EEC-IV Testing
EEC-IV Testing
Nickster225
07-28-2014 07:57 AM
Born24wheel
01-18-2007 06:13 AM
