recent discoveries
recent discoveries
Back again sirs,just found out I have 4.10 gears,tags still on axles,calling that a good find after replacing dirty air,fuel filters engine really woke up,they were nasty bad,that wont happen under my ownership!Bad news pesky leak under engine on trans cover plate worsening,seems to be diesel or oil or mix,engine so dirty its a $%^^ to see leak but I will get it eventually,putting white board under it to see what colors I have in morning,also found a bung type 1/8 or 1/4 npt fitting after turbo on exhaust side would this be an old egt hookup spot I could use?
Ah replying to myself here,but gotta get posts up to 25,anyway my leak is DIESEL dripping off trans access cover,looked black initially but diesel musta been grabbing oil on the way down,now,where the #$%^% is it comin from way back there,any ideas?fuel filter drain is closed,blow off from up front?,top of engine dry,so its happening in back somewhere?
Fuel bowl drain is the common source of the diesel leak. You can get replacement o-rings and download the instructions to fix it here Replacement O-rings for Ford Diesel Engines
Common issue and a cheap fix. For your fitting, you need to read EGT's pre-turbo so it sounds like the existing hole won't work for you.
Received 3,102 Likes
on
Ok will check fuel return line,since I did fuel filter this morning I checked and its dry around it,the guy before me said he constantly had water in fuel light and used petcock every startup,I'd like to extend hard line on fuel dump further down so it doesnt just puke all over engine looks like fun getting a hose and clamp up in there,do you guys think I should do the egt gauge on a truck that will see light to moderate pulling or is that just for highly mod psd's?
