t5 transmission shifter - Ford Truck Enthusiasts Forums
Old 09-17-2011, 05:50 PM
fordtruck52 fordtruck52 is offline
fordtruck52 is starting off with a positive reputation.
im putting a t5 5 speed transmission from an s10 in my 52 pickup. the only issue that i have is straightening the bend in the shift lever. it is more than robust and hardened. the problem lies in the plastic ball which would melt if i heated the steel. has anyone been able to straighten this lever without heat?
Old 09-17-2011, 07:29 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Isn't the plastic ball threaded on the shaft? It should unscrew
Old 09-17-2011, 07:38 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
I think the ball would be threaded too. maybe there's a glue to keep it from unthreading easily?
As for bending, we have a 400,000 ton press brake at work.... no problems. If you were close by, I could do it.
Old 09-18-2011, 08:45 AM
Damifiknow's Avatar
Damifiknow Damifiknow is offline
Damifiknow is starting off with a positive reputation.
cut the T5 shifter and weld on the stocker. I think plastic ball pops off.
Old 09-18-2011, 09:57 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
BB-7213 .. Shift Lever Ball / Misc: 1932/56 4 & 5 speeds / Misc: 1957/69 M/T's.
Old 09-18-2011, 11:20 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Is the ball you are refering to at the bottom, the pivot for the shifter? Some of them are plastic from what I've heard. I don't think they come off.
Some S-10's have hollow shifters, not easy to bend without breaking. You can get a Mustang short-shift kit, even a stock Mustang shifter is an improvement and allows bolting a shifter to the stub down low. One of the short throw kits that has adjustable stops is not a bad idea because shifter forks can be broken from over-travel/over-pressure..
Old 09-21-2011, 06:07 PM
cts1954 cts1954 is offline
cts1954 is starting off with a positive reputation.
I cut mine at the proper angle and welded a shifter from a another truck on it, make sure you scarf the shaft so you can get a good weld. If it falls off it causes problems. Mine looks realy good and shift great in the garage.
Old 09-22-2011, 07:18 PM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
I welded a plate to the side of the short stick, then bolted my stick to that. It'll get covered by a boot. You can remove the ball, iirc you have to remove the pin first. I was playing with the spring washers as a way of adjusting the tightness and I had to cut some welds on the top plate, take the whole thing apart, then tack it back together. If you want to shorten the throw, redrill the hole for the pin higher up on the stick, then space the whole unit up an equal amount.
Bent 8ba fan blade 3twinridges 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 10-13-2016 07:12 PM
Park Brake lever boot 48 - 52 Jolly Roger Joe 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 01-06-2015 02:50 PM
52' Ford w/302 and c6 kickdown linkage question? 52' fordnut 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-13-2013 06:44 AM
swap 52 f-2 4 speed into 50 f-3 ? 41505379 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 01-25-2013 11:36 AM
transmission bearing? Danger_Dave Ranger & B-Series 15 03-08-2010 01:23 PM
Tags
944, buy, f100, ford, lever, model, play, porsche, s10, shift, shifter, t5, transmission, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
