2001 F150 Cruise Control not working - Ford Truck Enthusiasts Forums
Old 09-17-2011, 04:36 PM
gdubia gdubia is offline
gdubia is starting off with a positive reputation.
I am new here, but after doing some reading here, I am sure someone here can help me.
Last time I was at the dealer, the SM told me it would be about $300 to fix my cruise control. I don't remember what he told me the problem was, but I didn't have the work done at the time and figured I would do a little research on my own (so here I am).
I read several posts here about the cruise control on my model truck, but none quite exactly fit my symptoms, so here it goes: (The recall harness IS installed)
When I press my cruise switch at highway speed, nothing happens (except when it is raining outside - then the cruise light will come on very briefly and immediately goes back off). The first time I did the self diagnostic test there were no codes. Cruise light comes on once after each button - with no sequence of flashes following - so the static test passed, but I am not sure about the throttle lever moving since I am inside the truck pushing the buttons (I didn't think to look at the gas pedal - should this move too?).
Fast forward a couple of days....and ran the self diagnostic test again. Now I am getting 3 flashes after hitting the last button. So I popped the hood and looked at the switch. I had a little brake fluid around the pressure switch on the front of the master cylinder so I lifted the fuse and there also is a little fluid on the inside as well. I took a pic but I don't see any way to attach it here. I have not yet checked the fuse in the recall harness yet, but if it passed the static test initially, it should be good, right?
From what I have read, everything says to tryto replace the pressure switch first. I am told the switch from NAPA doesn't have the in-line fuse that the recall added. Does anyone know if the replacement switch from NAPA eliminates the possibility of a fire that the recall did? Or should I just go to the Ford dealer to get the part (and pay twice as much)
I know this is kind of a long post, but I have been tinkering with this for a few days now and I figured the more details I provide might help someone pinpoint the problem. Any insight would be helpful. Thanks in advacne.
Old 09-17-2011, 07:28 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Didn't we just go through all this this morning elsewhere?
Old 09-19-2011, 07:23 AM
Yes, but I figure the more people that see the problem, the better chance I have of getting a specific enough response that I can do this on my own.
Old 09-19-2011, 03:13 PM
1ATony's Avatar
1ATony 1ATony is online now
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
The air bag light isn't on is it.
Old 09-19-2011, 03:32 PM
no, no airbag light on
Old 09-21-2011, 01:02 PM
echo657 echo657 is offline
echo657 is starting off with a positive reputation.
Sounds like mine...Recall crap was installed but went out again. Brake fluid leaking all over it, no cruise. I bought another one, installed it and cruise worked just fine
Old 09-21-2011, 06:17 PM
Quote:
Numbers don't matter. What is important is *WHO* sees your question and answers. You want someone who knows what they're talking about, not just some average Joe who is well-meaning but clueless on how stuff works.
Go do what was recommended to diagnose the problem.
Cruise control problem, pressure switch bypass Pipeliner_86 Excursion - King of SUVs 8 12-03-2015 07:01 AM
Yet Another Cruise Control Issue... 94GreenTruck 1997 - 2003 F150 3 05-12-2015 12:39 AM
Cruise Control Conundrum Tugly 1999 - 2003 7.3L Power Stroke Diesel 38 11-25-2014 07:02 AM
2002 Ford Expedition Cruise Control Not Working hawesra 1997-2006 Expedition & Navigator 2 07-21-2014 08:01 PM
2002 cruise control diagnostics johndem 1999 to 2016 Super Duty 0 03-13-2011 09:34 PM
Tags
1997, 2001, 2003, contraol, control, crouse, cruise, duty, escape, f150, f350, fix, ford, problems, stopped, super, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
