2000 5.4 timing chain tensioner replacement - Ford Truck Enthusiasts Forums
Old 09-17-2011, 12:22 PM
kbsupercrew's Avatar
kbsupercrew kbsupercrew is offline
kbsupercrew is starting off with a positive reputation.
Can you change the tensioners and guides without removing the chains or getting the cam lock tools ? Doing a in truck repair to fix a squeal sorta noise at start up without the belt on coming from passenger side valve cover that lasts for about 5 sec. oh fyi CRC new freeze off works wonders compared to jb blaster for my tear down so far!
Old 09-17-2011, 05:59 PM
I need some help, I am trying to find the squeal noise underneath the passenger side valve cover. The chains and guides adjusters look ok from what I can see. The only thing I have a question about is the camshaft sprocket bushings...the passenger side sticks farther out than the driver side -- is this correct?? Are they both hanging out or just the passenger side?? Are these bushings supposed to be flush with the gear or ????
Anyone with knowledge please help... Thanks!
Old 09-17-2011, 10:04 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
I'm not positive but would think that the passenger side would have to stick out further in order for the chain to line up properly.
The chains are on two separate sprockets on the crank.
Old 09-18-2011, 12:53 AM
I looked into that and yes they are designed be that way and since the slides are not really worn down and no visible damage i think its the tensioner on the passenger side since the chain is really tight on both sides of the cam gear i can barely flex the chain with hard pressure compared to the driver side that has no play but is not super tight. i think the passenger side tensioner is jammed or something causeing too much pressure on chain causing noise against slides until oil can lube it at start up. Have you heard of these tensioners jamming causing chain to be super tight all the time?
Old 09-18-2011, 01:48 AM
phil6608's Avatar
Never really heard that before unless someone was using to thick of an oil.
Old 04-06-2012, 03:54 PM
Ojos Bonitos Ojos Bonitos is offline
Ojos Bonitos is starting off with a positive reputation.
i need help how to put the timing chains on a 2004 f150
Old 04-06-2012, 05:20 PM
You should post this in the 2004 - 2008 forum
Seeking input on tensioner/timing repair Joshua W McCarrel 2004 - 2008 F150 4 10-22-2015 10:52 AM
5.4 3v timing chain tensioner swap eggman36075 Modular V8 (4.6L, 5.4L) 2 08-02-2015 11:49 PM
Timing chain and tensioner kewing75 2004 - 2008 F150 1 02-28-2014 11:10 PM
Timing Chain Tension fishnowworknever 2004 - 2008 F150 2 10-28-2013 06:13 PM
Timing chain tensioner bjboyle 2004 - 2008 F150 27 01-20-2009 07:08 AM
Tags
2000, 2004, 2006, 54, belt, chain, expedition, f150, ford, miles, motor, rattles, rattling, replace, tensioner, timing, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
