POWER WINDOWS & RADIO electrical problem - Page 7 - Ford Truck Enthusiasts Forums
Old 11-12-2014, 02:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
  #91
Old 08-06-2013, 02:24 PM
Gazoo Gazoo is offline
Gazoo is starting off with a positive reputation.
Power window and radio inop?
It is the accessory Delay Relay in the instrument cluster losing power due to a bad/cold soldier joint. This should have been a recall (my opinion), thousands of vehicles involved.
The esaiest/10 minute fix is to change the cluster. This also changes your milage to that of the cluster. I have had many superdutys. I have three bad clusters on the shelf and one good one with 178,000 on it.
Pull the radio, the dash bezel pops off, 4 screws on the cluster, unplug, repeat in reverse.
  #92
Old 08-06-2013, 07:59 PM
monashee monashee is offline
monashee is starting off with a positive reputation.
I thought in the 06 the relay was under steering column middle bottom row. This is the one that clicks when gauges etc etc drop. I am wondering what sends a signal to this relay to turn off? Some have replaced the cluster and not had their problem fixed. Im considering running a power to this relay through one of my upfitter switches so I can switch it on when it goes off.
  #93
Old 08-06-2013, 09:25 PM
Windows, radio, reading & glove box lights inop
Sorry, I stand corrected. I was reading and commententing on several posts. I missed the fact that you were dealing with a 2006. My previous post is 100% correct for 1999-2004. I have not had the experience with later years. Did not mean to mislead.
  #94
Old 02-01-2014, 02:57 AM
sleeand4 sleeand4 is offline
sleeand4 is starting off with a positive reputation.
Had this same window / radio issue on my 2003 limited. Disconnected plug on rear of dash instrument cluster, waited 2 minutes and plugged back in. Everything worked fine after that.
  #95
Old 02-01-2014, 09:00 PM
Larry Grimes Larry Grimes is offline
Larry Grimes is starting off with a positive reputation.
Radio and lights not working.
Remove relays and use dialectric grease on pins of relays.DC volts are sensitive to resistence.some of the metals they use for the pins and sockets are not the same type and causes chemical reaction.I even did all the fuses.
  #96
Old 02-04-2014, 06:44 AM
jalowman jalowman is offline
jalowman is starting off with a positive reputation.
In need of help
I am new here and I dont know where to start. So here goes: on my 04 450 the wiring harness for the radio I have a constant hot and a switch hot. Well the switch hot is not hot. Checked the fuse and it dosent have power on it with the circurt tester i have it showes that the switch wire is ground when you turn on the switch. Cant afford to take it to local dealer ship here. Thank for any help.
  #97
Old 02-04-2014, 07:39 AM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
Quote:
Originally Posted by jalowman View Post
I am new here and I dont know where to start. So here goes my 04 450 the wiring harness for the radio I have a constant hot and a switch hot. Well the switch hot is not hot. Checked the fuse and it dosent have power on it with the circurt tester i have it showes that the switch wire is ground when you turn on the switch. Cant afford to take it to local dealer ship here. Thank for any help.
That is odd. Previous owner may have messed something up.
If you want to get your radio going, you could find a different switched hot wire (cigarette lighter for example) and splice into that.
Cut the switched hot wire on the radio harness. Take the end going to the radio and connect that to the cigarette lighter switched hot. Don't connect to end going into the dash or you will fry something out.
You will put a bit more load on the cigarette lighter circuit but it will get you going.
  #98
Old 03-28-2014, 02:52 PM
JN3 JN3 is offline
JN3 is starting off with a positive reputation.
I have had this problem for years. I've pulled and reset connectors, replaced relays, swapped fuses, beat on the dash, and pulled the instrument cluster to get to the Battery Saver Relay (the problem). The Battery Saver Relay, (part of the instrument cluster) continues to fail intermittently in supplying power to the Accessory Delay Relay (in the fuse panel below the steering wheel). I finally ran an emergency bypass circuit to supply power to the ADR through a switch. I don't mind losing radio function but I have to be able to open and close the windows. I installed a fuse tap to the rear power outlet fuse and ran a wire to a switch that I installed in the panel below the headlight switch. This switch has a red LED that reminds me that I am in bypass mode. From the switch I ran a wire to the ADR pin 87. I pulled the cover off of the relay and made a small hole just large enough to pass the wire inside and soldered the wire to the base of pin 87. Snapped the cover back in place and zip tied the wires. Works great. I leave the switch "OFF" and let the normal system work, but if I need to operate the windows and the system is in failure mode, I turn "ON" the switch, operate the windows and turn the switch back "OFF". I would have posted pictures but I haven't figured out how to do that yet. :-drink
  #99
Old 04-07-2014, 05:19 PM
JN3 JN3 is offline
Thumbs up POWER WINDOWS & RADIO electrical problem
Pics to accompany the above post by JN3
Library Slideshow by jnuncio3 | Photobucket
  #100
Old 04-12-2014, 03:44 PM
ericl72 ericl72 is offline
ericl72 is starting off with a positive reputation.
Additional thoughts
My truck, 2000 F350 7.3 deisel, is doing some similsr things. I have replaced the ignition switch and the accessory switch. The windows will work with the door oopen. This last time I messed with it, I took the GEM outcleaned all connections and since it seemd like a door problem I sprayd wd40 on all the lock areas. Now the drivers window went down and when I tried to raise it the GEM module makes a funny pulsating noise and the interior light flicker.
I think I need to replace the module.
  #101
Old 05-16-2014, 09:00 PM
TMKIOWA21 TMKIOWA21 is offline
TMKIOWA21 is starting off with a positive reputation.
ick same issue with my 02 lariet. will try the tricks and see what happens. thanks all
  #102
Old 05-17-2014, 08:59 PM
I checked on the cost for a GEM module---about 650.00 dollars. I took my truck to a good NAPA dealer close by. He charged me 2 hours of diagnostic time and found out that it was a ground that needed to be cleaned. He didn't tell me where, but I assume under the dash somewhere. I would look for any and all grounds.
  #103
Old 06-21-2014, 12:30 PM
cap_nut cap_nut is offline
cap_nut is starting off with a positive reputation.
Can you remove the cluster and still drive the vehicle "blind"? While the cluster is out for repair. Does this affect the odometer or is it just an indication so it will advance as driven? Thanks
  #104
Old 12-11-2014, 12:11 AM
goose5 goose5 is offline
goose5 is starting off with a positive reputation.
Fixed... I hope
So I'm driving around Monday on my day off and my instrument cluster and radio cut out, so I pull into my dealership(I'm the shop foreman and a ford master and diesel technician) and grab the wiring diagrams and head home. After doing some quick reading and scouring the wiring diagram i know my problem must be with the battery saver relay. So after finding this thread, and google searching repairs, all i can find is instrument cluster replacement and no schematics for the board chips and conductor paths. As a technician i would recommend a replacement since I can't guarantee a proper fix otherwise. For my own stuff... I'm semi-cheap, and just bought a VCM II so i don't have 500$ to drop on an instrument cluster. What i found is that I had very slight corrosion on the 4 pins of the battery saver relay. I have a small electronics kit at home so I took a little pick, scraped all the corrosion off i could from around the board, cleaned them off with electrical cleaner and then hit each pin of the relay with a 50w soldering iron enough to puddle the solder into the relay, and as a secondary benefit it seems to have pushed some corrosion to the outside of the solder puddle. I'll take my truck for a drive and let all of you know how it went. I'll post pictures when i get back.
  #105
Old 12-25-2014, 01:19 PM
floinc floinc is offline
floinc is starting off with a positive reputation.
Same issue of my 2002 7.s Super Duty, mostly is the summer when the cab is hot, usually fixes itself in 2 to 5 minutes. Was also hoping to find a solution or fix for this issue.
Power windows and radio problem Coobreeze 1999 - 2003 7.3L Power Stroke Diesel 38 12-20-2016 10:38 AM
04 F250 King ranch 4x4 electrical gremlins! 9Dark6 1999 to 2016 Super Duty 23 10-09-2016 08:57 AM
Where is the CENTRAL JUNCTION BOX? HOME WORKS Excursion - King of SUVs 33 02-18-2016 06:47 PM
Power Windows, Radio, map light switches don't work suddenly.. locash 1999 to 2016 Super Duty 18 12-31-2015 09:33 AM
intermittent gages, radio,pwr windows bobv60 1999 to 2016 Super Duty 21 08-24-2015 06:48 AM
Tags
2003, 60, dash, diesel, electrical, electronics, excursion, ford, interior, lights, power, problem, radio, start, trans, windows, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
