Drivers side power window problem.
Old 09-16-2011, 09:30 PM
gyrospinup's Avatar
gyrospinup
gyrospinup is offline
My left window would not come back up one day. Right side window works fine from left and right switch. Had been having NO problem with window prior to this. I swapped the #7 fuse located in the engine compartment fuse box with another 15 amp fuse and the window went back up. Now the window will not go back down. (up is lots better than down). Any suggestions will be greatly appreciated.
Chris
Old 09-16-2011, 09:43 PM
mblayton's Avatar
mblayton
mblayton is offline
If your fuse was blown chances are you have a bare wire grounding somewhere.
PMDRACER
1999 to 2016 Super Duty
09-18-2013 01:08 PM
tgbroom
Aftermarket Products
05-26-2004 07:02 PM
da cubs
1997 - 2003 F150
04-11-2003 12:38 PM
Quick Reply: Drivers side power window problem.
