Old 11-24-2014, 06:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
Print Wikipost
catalytic converter
Old 09-09-2011, 01:14 AM
zann's Avatar
zann
zann is offline
catalytic converter
Hi folks,
Looking for some guidance. I have a 1996 Explorer (not sure if it makes a difference but is Eddie Bauer edition). Has about 180000 miles on it, couple dents, but in all runs pretty good. Had a check engine light go off, about the same time it started running pretty rough. Took it in and was told the catalytic converter needed replacement (said it was a dual), along with the oxygen sensor and some of the spark plugs/wires. I was given a cost of about $1100 and change to fix. I cant really say I completely trust the garage, I dont think they would be dishonest, but I do think that they mark up their parts quite a bit. I am really on the fence as to whether I should have it fixed or should consider something newer. Blue book has its value to a dealer at $1400 for fair, and $1800 for good condition.
I have read around this website a lot the past few years and have gotten some good knowledge from its community, so I was hoping for some feedback both in terms of the price that was given to me and the value of having it fixed. I love the car, its always treated me right, and hate to see it go, but want to be practical. Any advice or feedback would be appreciated.
Thanks in advance
zann
Old 09-09-2011, 01:32 AM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
Welcome to FTE zann,
1100 is high, but in the ballpark for the repairs, cats are expensive.
Take it to another shop for another estimate.
Most people on FTE do this type of repairs in our own driveways and
garages, not saying you should do it, so get more estimates in the mean time.
At 180,000 miles, I am sure there are other things to do too.
1100.00 and you still own the truck.
Old 09-09-2011, 07:36 AM
explorerjwd's Avatar
explorerjwd
explorerjwd is offline
I assume there is a different procedure for bolt in versus weld in installations. Probably a cost difference for parts also. I am going through the same cat replacement process with my 94 Explorer - 140000 miles. The cat is a bolt in installation and I have priced the parts at Rockauto, Autozone and Advance Auto. Prices run fairly close amongst suppliers for Walker parts.
Cat - 15737 = $268.99
Gasket - 31372 = $11.69
Gasket - 31545 = $8.49
Bolt Kit - 36129 = $10.33
Total = $299.50
I replaced the O2 sensors some time ago, got them from Rockauto for about $64 each, the local Ford dealer wanted about $116 each. Lesson learned do not source parts from Ford dealers.
Old 09-10-2011, 08:42 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
You may well need a new cat, but my guess is the cat is a victim, not the cause of your problems. A plugged cat should not cause it to run rough, it should only cause a generalized decrease in power.
How did the tech come to the conclusion that you need spark plug wires? Not questioning the competence of the tech, but all to often that is a quick fix guess at addressing a random misfire. I would have him pull and inspect the plugs, they may tell a better story of what is happening. Misfires can damage your converter, and if not corrected, can quickly destroy the new replacement.
Old 09-10-2011, 11:56 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Touche!.. concur 100% .. Philip
Old 09-18-2011, 12:10 PM
explorerjwd
On 9/15 the 17 year old catalytic converter was replaced on my 94 Explorer. The new converter was boxed with the front and rear gaskets so I returned the gaskets I had purchased to Advance Auto Parts. The money I spent was very reasonable compared to catalytic converter replacement prices quoted by others. The labor rate was a bit higher than expected because the original converter had studs in the front flange and the rear flange bolt heads had rusted to a rounded condition. Front flange studs and rear bolts had to be cut to remove the original converter.
The vehicle runs much smoother and the exhaust smell is gone. I reset the computer just in case it needed to relearn the new relationship of readings from the O2 sensors.
Wagner Cat - 15737 = $268.99
Wagner Bolt Kit - 36129 = $10.33
Parts Total = $279.32
Mechanics Labor - $158.37
Total Cost = $437.69
Old 09-18-2011, 12:33 PM
aquanaut20's Avatar
aquanaut20
Thanks for the report... Philip
Old 09-19-2011, 08:30 AM
KhanTyranitar
You say it runs smoother, but is it completely smooth. I still think you have a misfire or incomplete combustion. A new cat can mask the smell, but it is not designed to handle that. I still think you need to do more troubleshooting and find the cause of the failure, otherwise you are gonna find yourself replacing the cat again.
Old 09-19-2011, 12:24 PM
explorerjwd
I think I should post the reason I replaced the converter. As I stated in my previous post it was 17 years old. But, the main reason for replacement was noise. It had developed a fairly significant rattle at idle and low rpm. I didn't want to take the chance small particles would someday clog the exhaust flow and cause me grief alongside some busy major highway. I realize there are other reasons for converters to fail but mine was purely due to age.
Old 09-19-2011, 12:34 PM
explorerjwd
Mr. KhanTyranitar: After I submitted my previous post, I finally realized you are apparently addressing ZANN's first post in this thread. I think you have myself and ZANN confused. I was not addressing any performance problems with my posts. I was merely giving feed back on expenses and effects related to converter replacement.
chrislambing
1999 to 2016 Super Duty
05-25-2023 06:17 PM
thousand_mile_stare
Escape & Escape Hybrid
18
05-09-2016 01:37 PM
7283-F250
Exhaust Systems
10-08-2009 04:42 PM
Scott97F150
Exhaust Systems
10-02-2007 08:28 AM
stutterstan
Exhaust Systems
02-18-2005 11:34 PM
Quick Reply: catalytic converter
