come on guys i know you guys can answer this in 2 seconds
just bought these wheel spacers-------- 4pc | 2" inch | 8x165 to 8 x 165 | Wheel Spacers | 8Lug Adapters | 9/16" | eBay
Spacer Specifications
- Quantity: Four (4)
- Thickness: 50mm or 2 inches
- Centerbore: 125 mm
- Vehicle Hub Bolt Pattern: 8x165.1 or 8x6.5
- Wheel Bolt Pattern: 8x165.1 or 8x6.5
- Thread Type of Pressed-in Studs & Supplied Lug Nuts: 9/16"
these studs------http://autopartsway.amazonwebstore.com/Gorilla-Automotive-Products-75197-Lug-Nuts/M/B000CMH4RI.htm
Lug Nut Thread Size 9/16-18 RH in.
Lug Nut Seat Style Shank
Lug Nut Head Style Standard
Open End Design No
Lug Nut Shank Length (in) 1.000 in.
Lug Nut Shank Diameter (in) 0.740 in.
Washer Included Yes
Washer Shape Centered round
Washer Outside Diameter (in) 1.125 in.
Lug Nut Material Steel
Lug Nut Finish Chrome
Lug Nut Overall Length (in) 2.000 in.
Wrench Size Required (in) 7/8 in.
Quantity Sold as a set of 4
for these rims
do u know it this will all fit together
Open End Design No
Washer Included Yes
for these rims
From what I have read on here you will need the part # 75187 and they are 1/2x20, NOT1/2 x18. Like I said this is what I have read on here alot lately.
Since the adapters are 8 on 6 1/2 to 8 on 6 1/2 they should work, but the company web site for the adapters says they will NOT work on your truck??
Good luck and let us know what you get worked out, I am interested to find out too.
His closed knuckle axle has a pretty limited turning radius so i wouldn't think interference during lock to lock would be an issue.
I dunno.
im running the spacers to get away from my bendix unit with 265 70 r16s i still hit it. the ones i am showing are 16.5 rims thats all i like to run. with a 12.5 wide tire it rubs really bad so i wanted the spacers. besides that spacers look badass on these trucks. i dont mind replacing the stuff they are hard on.
thanks for all the input guys. i can always get good help here.
I've never known any highboy to rub the Bendix unit with 35's, even with the most tired of springs, but once you get up around 36 or 37's yea they'll rub the Bendix if the springs aren't fresh.
