6 inch lift questions for 86 ford bronco? - Page 2 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 09-23-2011, 12:12 AM
ErrorS ErrorS is offline
ErrorS is starting off with a positive reputation.
My first truck was a 300, didnt know enough about vehicles to appreciate it though. One of these days I'm going to build a pure trail Bronco with a built 300.
Old 09-25-2011, 10:14 AM
|WYG|SS's Avatar
|WYG|SS |WYG|SS is offline
|WYG|SS is starting off with a positive reputation.
Yeah I love the 300 in my 93 f150 my first truck I mean the motor has been hydrolocked once so I rebuilt it and its still running strong. I do like it in the bronco with the granny gear. Stock with only 31s I gave made it thru places some big trucks go. Just throw it in low and give it.
Now with the 6in lift I'm installing it and the front sits about 2-3in higher than the rear, will this go go down after driving it a little? It does look sweet tho besides the don't being higher
Old 09-25-2011, 03:03 PM
No clue, what brand lift? is it 6'' springs in the rear, 6'' in the front?
I put 6'' springs in my rear, with the stock angle block it was sitting a good 3+ inches higher than my 5.5'' Deaver springs in the front.. I couldn't stand it and repacked my rear springs to bring it more in line with the front (and to soften the springs up)
also eventually going to replace the stock block with just an angled shim to drop it another inch or so, and give me enough room to add another leaf if I need to, to combat wheel wrap.
Old 09-25-2011, 09:40 PM
|WYG|SS's Avatar
Well rough country lift. The front sits 2in higher than the rear. But when I drive it my front tires are riding on the sidewall its that bad of an angle. But when I back up the the top of the tires angle in and looks level. I'm going to do ball joints in a couple weeks and maybe the stearing swap to the top of the mounting hole. I'm thinking their is soo much stress with the stearing that if I swap I it will lower the front. When I drove it every bump I hit or I couldnt go over 35 that the truck swayed side to side sometimes bad
Old 10-05-2012, 11:16 AM
BroncoBOY223 BroncoBOY223 is offline
BroncoBOY223 is starting off with a positive reputation.
Quote:
Originally Posted by greystreak92 View Post
I'll second the notion to keep the 300... I mean, trading 2 cubic inches for less power on the bottom end where the heavy Bronco really needs it will basically gain you two cubic inches, two pistons, two more spark plugs to buy and about a 12% reduction in mileage. Besides, when was the last time a 302 went 250,000+ miles before needing an overhaul?
my bronco has the 302 and its at 207,400 without and overhaul ever. still running strong with no problems
Old 10-05-2012, 07:24 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
When you make it to 250K let us know. Typical 300 might need valve work on the exhaust side by the time you get to 300K.
Old 10-05-2012, 09:01 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
The first truck I ever owned had a 300, and the engine was tough as nails.
The truck I got after that was an EFI 302, when it was brand new it worked great with stock tires.
35 inch tires sure made life hard on that engine.
Now I have a Bronco with a newly replaced 351 and I seem to always
have the need to hear it sing!
As for the lift, although I have not tackled my lift yet, if going with a 6 inch,
consider doing an SAS.
IF you do use a TTB aftermarkert kit, please do your self a favor and get extended radius arms.
Old 10-06-2012, 01:00 PM
1_ton_bronco's Avatar
1_ton_bronco 1_ton_bronco is offline
1_ton_bronco is gaining momentum as a positive member of FTE.
I love the 300.. I have a newer one out of a 95 f150.. and older one sitting in a rat rod.. good motors man.. as for my 351's .. one has184k and 150k
Old 10-06-2012, 03:31 PM
NewEnglander's Avatar
NewEnglander NewEnglander is offline
NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.
Hmm seems like I have that same problem haha, nothing like flooring it to 4k rpms and listening to it purrr well more like scream lol
Old 10-06-2012, 03:36 PM
khadma's Avatar
Carpenter Local 745
Quote:
Do you hear this phrase from the woman in the passenger seat too.......
"slow down, your going too fast."
(Keep it clean you guys) this is a G rated program.
Old 10-06-2012, 05:23 PM
Nah, faster is better according to her. (...as long as we are just talking about the passenger seat.)
Lift and tire fitment on a 84 bronco ii Tim Shearer 1978 - 1996 Big Bronco 1 06-15-2016 12:16 PM
6 or 4 inch lift with 33s 86fsbronco 1978 - 1996 Big Bronco 20 04-02-2014 02:12 PM
Bigger lift for my 79'? darkpurp1e 1973 - 1979 F-100 & Larger F-Series Trucks 13 05-02-2012 08:10 PM
Top heavy 6inch ItsAFord55 1987 - 1996 F150 & Larger F-Series Trucks 48 12-21-2011 03:18 PM
99 f-250 5.4 pushing 36''s? lift?? 78'fordtruckguy 1999 to 2016 Super Duty 8 06-01-2008 01:25 PM
Tags
1978, 1979, 1996, 350cfm, 351m, 450, 6in, 79, bronco, ford, inch, inches, lift, lifted, mpg, vibrates
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
