2003 Ford F250 6.0 Crank/No Start!!! HELP!!!! - Ford Truck Enthusiasts Forums
Old 09-16-2011, 05:18 PM
Scooter7227 Scooter7227 is offline
Scooter7227 is starting off with a positive reputation.
Angry 2003 Ford F250 6.0 Crank/No Start!!! HELP!!!!
The truck will crank but will not start. I turned the truck off got back in it about 10 minutes later and all it will do is turn over. I just changed the oil and filters (Fuel Filters Also).
Old 09-16-2011, 05:35 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
motocraft oil filter
Old 09-16-2011, 06:15 PM
Yeah everything is motorcraft
Old 09-16-2011, 07:44 PM
BLADE35's Avatar
so you did the oil change today and go to start the truck and it just turns over and no start????????
there is a oil filter drainback in the bottom of the oil filter housing that could be stuck
other than that try to unplug fan clutch harness and see
and also unplug ICP under the turbo and see if it starts
have you scaned for codes
any gauges
and go thru this
http://www.ford-trucks.com/forums/87...condition.html
Old 09-17-2011, 02:21 PM
I changed the oil and filters after the problem occurred. I have unplugged the fan clutch harness also and it would still just turn the engine over, but not crank. No codes showed up on the scanner either. I don't have and gauges (YET)!! I did print your link and will try and trouble shoot these today.
Old 09-17-2011, 11:55 PM
HELP!!!!!!
Old 09-18-2011, 12:34 AM
BLADE35's Avatar
checked fuses
can you hear the fuel pump cycle the first 20 seconds or so when you turn the key on
did you try this link
Here^^^^^^^^^^^^
Long Crank, No Start, Cycle Key, Long Crank, Truck Starts, White Smoke Kingkong0192 1994.5 - 1997 7.3L Power Stroke Diesel 13 08-20-2016 04:52 PM
Hard starting after sitting a few days. JPMallory 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 08-01-2016 08:33 PM
86 F 150 cranks ~ no start ITSA'G'THING 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 06-02-2011 11:06 PM
no start after fuel filter change oldkountryboy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 08-22-2010 01:01 AM
truck wont run dtc's # p1670 and p0340 johnt471 1999 - 2003 7.3L Power Stroke Diesel 5 01-05-2010 10:00 PM
Tags
03, 2003, 250, 60, 60l, clutch, crank, cranking, cranks, diesel, f250, f350, fan, ford, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
