Starter Solenoid Relay Question
Does anyone know why some models have this round starter relay instead? Is there a difference between the one below and the first one I posted that is more of a square shape?
This round one is the relay my truck came with, but the large terminals are just too close together. After nearly jumping out of my skin for about the third time this year because I accidentally bridged the two terminals and the starter began spinning, I would like to switch to the other style shown in my first picture. Will there be a problem doing that?
The photo in post 1 is the older style, better built I think.
I saw a you tube video of the inside of the newer style relay, I understand why they dont last long.
The "S" post goes toward the battery, "I" toward the starter. But it is just a relay and doesnt care about the direction of the curent flow thur the 2 big terminals.
Originally Posted by ArdWrknTrk
There is no polarity unless you purchase a Diode Suppressed version.
I checked RockAuto, and it seems that the first relay I posted was used from 1979 - 1984.
The other style in the second picture was used from 1985 and up. I am not sure why the design was changed, but since my truck has a carburetor and Duraspark ignition, it should work fine on my truck.
Handling both of these relays, I can tell you that the one in the first picture (older style) is a bit heavier and more solid than the newer style.
Sorry, I don't know much about electricity. What does this mean?
Diodes can act as one way 'valves' or can be used to limit current, as a 'zener' diode does.
Diode suppressed solenoids keep the pulldown electromagnet of the solenoid from acting like an ignition coil and spiking voltage when the current is removed.
Originally Posted by gfw1985
Watch out for some of the newer models. At some point they did away with the "I" terminal. I think it was an 86 Ranger I was working on had that newer style.
S is the signal terminal to trigger it and I is the ignition terminal to provide 12v to the coil for starting, at least thats how my 68 is wired with the old points system.
Keep in mind the I terminal will not trigger the relay and if installed backwards the I terminal will always be hot.
