Compression test questions
I've done compression tests before but I've always just pulled one plug at a time then replaced them when moving on to the next cylinder. I'm wondering if warming up the engine, then pulling ALL the plugs, then replacing them one at a time after testing each cylinder will ruin the readings. I.E. so when testing the first cylinder the other 7 have no spark plugs in, and by the time I'm testing the last cylinder the other 7 all have their spark plugs in. This obviously creates huge vacuum leaks when those cylinder's intake valves are open, I'm just wondering if this matters. If it's necessary or not to have the other cylinders sealed up while testing compression.
So that means I've been doing it wrong up until now. Sounds about right
Thanks for the replies.
1954wrecker
20
06-27-2018 09:16 PM
rdweathers
01-03-2013 07:48 PM
Boltgunner
17
02-06-2006 10:58 PM
