Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Minnesota Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Minnesota Chapter Join Chapter, Leader: fordpower88
  #1 (permalink)
Old 09-16-2011, 07:31 AM
toby tough toby tough is offline
Garage is empty, add now
toby tough is starting off with a positive reputation.
fast idle and winter is on the way
hey guys! a newbie here with a question.i have a 92 f150 with a5.0 and a really high idle. i have replaced the tps,map sensor, iac, and temp sensor,but still not fixed.checked all the vacuum lines and also pulled out a lot of hair in the process. i suspect a manifold leak some where under the upper intake. is there an easy way to check it?
  #2 (permalink)
Old 09-16-2011, 07:38 AM
dlibson's Avatar
dlibson dlibson is online now
2005 Ford F-450
dlibson is a name known to alldlibson is a name known to alldlibson is a name known to alldlibson is a name known to alldlibson is a name known to alldlibson is a name known to all
Get a can of brake cleaner, and with the engine running spray around all the intake gasket areas. If there is a leak, the idle will change when you spray it...
__________________
David
2005 F450 6.0 CC XLB DRW. Sinister Coolant Filter, Blue Spring, Straight Piped, Edge Juice Platinum w/attitude!
1985 Ranger 2WD- 4.6 V8 PI, 91 Front Clip
  #3 (permalink)
Old 09-16-2011, 08:07 AM
DieselCamper01's Avatar
DieselCamper01 DieselCamper01 is online now
2001 Ford F-350
DieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to behold
Welcome to the MN chapter and FTE Toby!
__________________
Jay
2001 F350 Lariat CC LB 4X4, Various mods
http://www.roadsidehelpnetwork.org/
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
