The Ultimate Super Duty Picture Thread.
Thor,
That sucks man...
Nice job on the repair though, I hope she's doing well
Cowboy,
Truck looks great & welcome to FTE
I must say, I hate yellow Lenses but for some reason they work well on your color combo. Also the updated color matched Mirrors & Buckmark, plus the black accessories of course....Really like your Truck man
That sucks man...
Cowboy,
Received 5,158 Likes
on
I replaced the following almost exactly two months after the initial purchase from the Ford dealer;
STC fitting
IPR valve (damaged seat)
ICP sensor and pigtail(reading incorrectly)
Oil cooler (clogged)
Coolant changed to ELC
Coolant filter
EGR cooler changed to newer "tube" style
EGR valve (bad motor)
Rebuilt the turbo
Cleaned and lubricated the VGT vanes and unison ring
Fan clutch
CAC boots
CAC (ruptured at end cap due to overboost)
Fuel filters (had moss growing in the lower unit)
Oil changed to T6 5w40 (dealer had 15w40 in it)
Front brakes/calipers/brackets (cracked pistons and damaged slide pins from a botched brake job)
Rear brakes/brackets (stuck slide pins and worn out pads)
Trans fluid change and new filters
Water pump
Thermostat
Accessory drive belt
Alternator
+ battery cable
Batteries
Brake fluid flush
Power steering fluid flush
Front tires
I'm towing the trailer to Burlington, VT for the 4th with the fam. I'm confident it will do well now.
I'll be able to monitor everything better now since I've replaced the SGII with
on
I had it all fixed up the next week. I found a laundry list of problems in the initial teardown, but since I had only owned the truck for about a month at that point, I now know everything is good.
STC fitting
Coolant filter
Rebuilt the turbo
Fan clutch
CAC boots
Water pump
Thermostat
Alternator
+ battery cable
Batteries
Brake fluid flush
Front tires
I'll be able to monitor everything better now since I've replaced the SGII with this.
STC fitting
Coolant filter
Rebuilt the turbo
Fan clutch
CAC boots
Water pump
Thermostat
Alternator
+ battery cable
Batteries
Brake fluid flush
Front tires
Ughhh.... lol. I suppose I'll stick with my 5.4L until I actually have to tow something heavy.
A buddy of mine just bought a 2007 F350 SRW, one of the special editions, with the 6.0 in it. Drove from the lot to Snyder Performance Engineering, which is a guy who we went to high school with's shop, and immediately put like $7k in the motor to bullet proof and then upgrade it. He never said what exactly he did to it, but it threw me into the passenger seat like we were in a Mustang GT. I could not believe how much go a 7000lb truck could have...
