Great video. You want to try something crazy? Drive a truck with a 900lbs snow plow at 50km/h. The snow flying up over the hood covering the winshield.
Dennis you cant get that load any more level than that!
Never seen that type of load level bar setup. Hope those lower brackets are completely bolted through the Frame??
Awesome how it works to throw the weight up front of tow rig.
Thanks! It's the dual cam system by Reese. It's a load leveling and sway control system in one. I love it. My dad had it on his old trailer too. Yes, the lower brackets are bolted through the frame.
It took quite a bit of playing around to get it all dialed in the way I want it. I hitched and unhitched a half dozen times, adjusted the tilt of the hitch head, took lots of measurements, etc.
May I suggest that if your trailer is swaying then it might be loaded incorrectly. This use to occur with mine when an inexperienced employee from a landscape supply yard would load my trailer to close to the rear with gravel or soil. Also check the hitch height. Had too short a hitch on the lifted 150 and trailer was not level causing swaying.
That could be possible, we have two mowers in an enclosed 16ft trailer and we put the heaviest towards the front but the rear one may still offset it enough. I bought a drop hitch so the trailer sits pretty level but other than that it never use to sway before my lift.
