The Ultimate Super Duty Picture Thread.
#8371
While the actual alignment should be the same as before the steering wheel would be off. The Steering box is mounted to the frame. When you lift the truck you are increasing the distance between the steering box and the axle. You are trying to use the same linkage without adjusting it to cover a greater distance. This would make it so you have to turn the steering wheel to get the wheels back straight. There must be some kind of adjustment though.
Once I get these tires installed along with the lift I'm going to see if I can talk the dealer into adjusting the TMPS settings the the PCM so I can get that stupid light to go away. The last one refused because I'm not running a Load Range E tire right now.
#8374
#8375
I would recommend finding F350 blocks, and a add a leaf. I have a readylift kit on my truck, and cant get rid of Drive Shaft Vibration. The blocks they gave me are tapered, and I believe they need to be flat.
(These are the only differences I'm noticing on others truck's. and they don't have chatter.)
*Just a thought if u have a "constant vibration" while driving (I did not) maybe your Carrier Bearing needs to be spaced down (my Kit came w/a Spacer)
I have pic's if u need/want to see them
#8378
#8379
Love the truck nike! I have a soft spot for charcoal/black trucks lol, looks like mine but a crew cab and not chrome bumper up front.
Did your truck have a plow prep package? I like the ride height but mine is tall it makes my tires look small and i have the same size tires/rims, i did the same lift 2.5" level, 5" rear blocks (3" total lift). We're both gasser's too so the weight up front shouldn't be much different.
#8380
#8383
I gotta say I love your color combo as well it fit's the theme of your truck perfectly. Mine looks nice on the outside but inside was aggravating me because it was work truck inside and...truck outside lol.
#8384
I ride my truck hard at the dunes, but not like this guy
https://www.youtube.com/watch?v=uM-M...ature=youtu.be
#8385
