How to take apart a 8.8" 3.55 axle???? - Ford Truck Enthusiasts Forums
Old 09-15-2011, 07:57 PM
EZFEED's Avatar
EZFEED EZFEED is offline
EZFEED is starting off with a positive reputation.
Smile How to take apart a 8.8" 3.55 axle????
First time tearing into this. The passenger side seal blew and the outer wheel bearing burned up. Now I can grab the flange and wiggle it with 3/8" of slack.
Haven't opened it up yet but wanted to get some pointers. Is it the usual C clip affair? Do I need to remove the backing plate? etc? Any pics or anything would greatly help
Specs:
8.8" ring gear
3.55 ratio
Open diff
Drum brakes
Comes off 4.2L 2000 F-150 XL supercab
Old 09-16-2011, 12:22 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
C clip, but not sure about backing plate.
This is interesting:
http://www.explorer4x4.com/axleseals.html
More:
http://www.pirate4x4.com/forum/showthread.php?t=806448
Old 09-16-2011, 02:12 AM
EZFEED's Avatar
Thanks so much!!!!!
Old 09-16-2011, 02:03 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Yes, you have to remove the backing plate. Once you do, there will be a small bolt holding the crosspin in place. Be extremely careful with this bolt. It's very common for it to snap off and then you are in a world of hurt. Once you remove it, the crosspin will come right out and then both axles can be pushed inward to expose the c-clip. The clip comes out and the axle will slide right out.
Old 09-16-2011, 03:40 PM
"Backing plate". Yes, the cover comes off the back of the differential.
I think the OP was talking about the brake backing plate at the wheel. Not sure you have to pull that.
Old 09-16-2011, 09:12 PM
EZFEED's Avatar
Yes I meant the brake backing plate. Thanks!!!!
8.8 or 9.75 rear axle? AUTOHAUL 2015+ F150 14 09-24-2016 04:37 PM
Alxe tag help abrarham 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 03-13-2013 06:26 AM
Junk yard differential xxshine 1987 - 1996 F150 & Larger F-Series Trucks 12 02-05-2012 08:15 PM
ford 8.8 open rear end hard to change to lsd Jason302 1987 - 1996 F150 & Larger F-Series Trucks 2 07-20-2011 08:24 PM
Dana 44 spool in the front 351slug Offroad & 4x4 17 11-12-2007 07:20 AM
Tags
1983, 355, 88, 99, axle, differential, end, expedition, f150, ford, interchangable, rear, slack, universal, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
