1948 F Series Trucks - Ford Truck Enthusiasts Forums
Old 09-15-2011, 06:55 PM
Barthog34 Barthog34 is offline
Barthog34 is starting off with a positive reputation.
Hi guys,
I am looking at 2 x 1948 F Series trucks.
Plates on the dash identify them as T73100 and T3430 Models.
Can anyone shed more light on what I am looking at here?
I cannot find any other identifiers on them.
The T73100 has a GVM of 13,000 lbs. Not sure about the T3430.
Cheers,
Bart
Old 09-15-2011, 07:29 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Never heard or seen these trucks have plates with those numbers affixed to the dash. Maybe it was a "fleet" number???
You can find the serial number in three places. There should be a stamped plated affixed on the inside of the glove box door. The other plate is affixed with rivets in the upper right hand corner of the cowl in the engine compartment. The thierd spot is a stamping on the right frame rail near the front straight axle.
Old 09-15-2011, 07:34 PM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
Check serial number on top of frame rail on left hand side in front of steering box.
Allan
Old 09-15-2011, 07:50 PM
51PanelMan's Avatar
Quote:
Allan
U.S. trucks had them on the right side frame rail.
Old 09-15-2011, 08:15 PM
OK. Had a nother look.
There are sme numbers stamped on the firewall in the engine bay (no I.D. plates or tags).
7C81
4476
That is what I can find.
Does not appear to be anything on the top of the chassis rails in the engine compartment. Although there is a fair amount of cleaning required before I can be 100% sure....
Do those numbers mean anything to anyone?
Old 09-20-2011, 09:46 PM
Ok. Second 48 F? has this stamped on the firewall.
7C31
4032
Must mean something!
Can anyone help me out?
Thx
Bart
Old 09-20-2011, 11:18 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Bart, I noticed you're in Australia.It's helpful if you can update your profile so it showsyour location in the little box on the upper right.
There are some FTE members from your country,hopefully one will show up soon who's familiar with numbering/data plate info from Australia.Good luck,and welcome to FTE.
Steve
Old 09-20-2011, 11:40 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
C was the designation for Canada production
81 was normal designation for standard cab in both US and CAN
Beyond that I don't have info on AU serial numbers.
Old 09-21-2011, 12:13 AM
Thanks Steve. Profile updated!
Old 09-21-2011, 12:20 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
None of the numbers mean too much, to me, especially the "T" numbers. The firewall stampings seem to be missing a few characters from what we would consider normal. Do you know if the trucks are US or some other countries production? Are they right hand drive?
Old 09-21-2011, 01:12 AM
Both are definitely RHD.
Old 09-21-2011, 01:46 AM
51PanelMan's Avatar
WE NEED PICTURES!!!!! RHD trucks are obviously "rare" to us in the states. From what I remember, trucks for sale in Australia were made in Canada. I just looked through the only Australian Ford truck brochure that I have (1952), but it doesn't mention anything about the model designations.
We don't get too many Australian Ford truck around here. That's why not much info.
Old 09-21-2011, 01:51 AM
OK. How do I go about inserting pictures here???
Is there a newbie "how to" thread??
Old 09-21-2011, 02:05 AM
51PanelMan's Avatar
Read here for the instructions: http://www.ford-trucks.com/forums/67...-pictures.html
If all else fails, you can email them to me at modelking2000 at hotmail dot com and I'll post them for you.
Old 09-21-2011, 02:34 AM
lexcoe's Avatar
lexcoe lexcoe is offline
lexcoe is starting off with a positive reputation.
Pretty sure all the aussie delivered trucks came from Canada and we had a wider box on the back, skinnier fenders (guards) Pictures will be the best way to identify what you have. Welcome to FTE BTW. John
Time for a Battery Powered Impact Wrench.... ISurvivedNMU General Diesel Discussion 8 02-15-2014 11:10 AM
Need help with identifying my truck jazzygreen 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 07-09-2013 12:41 AM
Exhaust Manifolds Necco-2 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 1 06-22-2013 08:44 PM
Exhaust Manifolds Necco-2 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 06-07-2013 08:26 PM
replacing rag joint w/ u-joint weez440 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-20-2011 05:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
