1948 F Series Trucks - Page 2 - Ford Truck Enthusiasts Forums
Old 09-21-2011, 03:29 AM
Barthog34 Barthog34 is offline
Barthog34 is starting off with a positive reputation.
Thanks for the tips on how to post pics.
Here we go.....
This is the larger of the 2 trucks.
Old 09-21-2011, 03:33 AM
And the other one...
Old 09-21-2011, 07:10 AM
lexcoe's Avatar
lexcoe lexcoe is offline
lexcoe is starting off with a positive reputation.
is that a spinner ute i see in the background?
Old 09-21-2011, 08:55 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
If they were US trucks I'd call the smaller one F4 or F5 because of the single spd rear axle with duals.
Interesting to see the parking lights on the fender like Canadian Merc trucks, but don't see evidence of the trim.
The frame stampings are usually light and hard to read. I scrub the frame with steel wool and then use a strong light at an angle.
Canada (producer of your trucks) used a serial number on the order of: FM81V4812345
This website might help, but I find some of his info confusing.
Mercury and Ford Truck Data Can
Old 09-21-2011, 09:47 AM
Rojak Rojak is offline
Rojak is gaining momentum as a positive member of FTE.Rojak is gaining momentum as a positive member of FTE.
Welcome to FTE! Looking forward to seeing some pics of those trucks to see the differences. I've seen a few pictures of "utes" which I know is a different thing but not something seen much in the states.
Rob
Old 09-21-2011, 10:47 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Nice trucks! Still weird to see the RHD in the cab. It's like bizzaro world.
I agree with mtflat on the models. I saw the park lamps in the fenders and the ommission of the trim, too. Misture of Merc fenders with Ford model designation.
Old 09-21-2011, 11:30 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
The RHD definitely looks odd (to us, at least ;o), but amazingly interesting. The larger truck has the wider grille like an F-7 or F-8. I've never even seen a picture of any of these trucks before without the lights in the ends of the upper grille bar. Fascinating. If you can post pictures of any tags or marking you can find, that would be helpful.
Old 09-21-2011, 12:43 PM
Thanks for posting!
I agree... very interesting and bizarro!
How about some Ford ute pics in another thread. I love those utes! Too cool.
Rob
Old 09-21-2011, 02:37 PM
51PanelMan's Avatar
Bit of trivia... crawl under your standard LHD truck and look at the transmission crossmember and the right side frame rail. It's mirror-image of the left side of the crossmember and frame to allow attachment of the brake master cylinder and pedals for the RHD. Also, look at the passenger side floor and compare it to the driver's side. You'll see that the area where the pedals would go through the floor on the pass side is stamped for the cut out that matches the left side.
Also, reverse the instrument cluster and turn the gauges upside down and you have yourself a RHD cluster.
Old 09-21-2011, 03:16 PM
Greg M-47 Greg M-47 is offline
Greg M-47 is starting off with a positive reputation.
I never even noticed the fender lights the first time I looked. That does look like the Mercury light mount. Got any close up pictures of the fender mount and the light bezel ??
Greg M-47
Time for a Battery Powered Impact Wrench.... ISurvivedNMU General Diesel Discussion 8 02-15-2014 11:10 AM
Need help with identifying my truck jazzygreen 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 07-09-2013 12:41 AM
Exhaust Manifolds Necco-2 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 1 06-22-2013 08:44 PM
Exhaust Manifolds Necco-2 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 06-07-2013 08:26 PM
replacing rag joint w/ u-joint weez440 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-20-2011 05:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
