Wheel Option - Ford Truck Enthusiasts Forums
Wheel Option
Old 09-15-2011, 06:13 PM
HkyswiM HkyswiM is offline
HkyswiM is starting off with a positive reputation.
Wheel Option
I recently purchased a 1955 F100 and understand the wheels are 5X5.5 bolt pattern. I was wondering if anybody knew of a more modern wheel from another vehicle which would use this pattern as I am having a hard time finding them.
Old 09-15-2011, 08:20 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
All F-100s and F-150s up to 1996 have the same pattern, many with similar offset and backspacing as your stock steel wheels. Plenty of choices I'd think. Stu
Old 09-15-2011, 10:08 PM
Moe Craig's Avatar
Moe Craig Moe Craig is offline
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
Dodge Ram also used 5x5.5 I have a set of 16x7 on the back of mine
and the fronts are 15x6 Ford F150
I put the Ram center caps on front and back
Old 09-20-2011, 11:35 AM
Thanks for the replies, I have began my search for the wheels I want.
Old 09-20-2011, 11:52 AM
jmadsen's Avatar
jmadsen jmadsen is online now
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
I'm going to run stock steel 16" wheels with trim rings and hub caps on my 51 F1,
here are some Forg Mag Slot wheels that would fit too.
I took them on trade and don't know exactly why/ going to sell them I guess.
Old 09-20-2011, 12:20 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Last year for F100's = 1983, and...
Some 1980/83 F100's have 5 lug 5.50" bolt circle wheels, some have 5 lug 4.50" bolt circle wheels...as it depended on whether optional power brakes were installed.
Ridiculous! Why did Ford bother? And...if you have 4.50" wheels, the rear drum brakes are 10" x 2 1/2" / All other 1968/83 F100's, 1975/96 F150's have 11" x 2 1/4" rear drum brakes.
F150's went to metric wheels in 1997, but Econolines did not. All 1975/2011 E150's have 5 lug, 5.50" bolt circle wheels.
Same 5 lug and 5.50" bolt circle as used on 1975/96 F150's, some 1980/83 F100's, 1953/79 F100's, 1948/52 F1's, 1932/47 "Commercials."
Styled Steel and Styled Aluminum wheels introduced in 1977 E150's, F100/150's. Bronco's used the same wheels beginning in 1978.
The center cap (Ford called it an ornament) attaches to the wheels with 3 expanding anchors and 3 screws.
3 anchors press into the wheels (the 3 holes are within the bolt circle), then the screws thread into the anchors.
Steel wheels used steel anchors, aluminum wheels used nylon anchors. Both plastic chrome and black plastic caps were used, as well as chrome and black screws.
If removing the caps, then re-installing them, do not use the anchors more than twice...cuz if you do, when rounding a corner, the caps and screws fly off! Sold a lotta caps/screws back then, mainly for this reason.
Old 09-20-2011, 12:36 PM
Moe Craig's Avatar
Those are the rims I'm planning on putting on the rear of mine... what is the center hole dia?
Old 09-20-2011, 12:40 PM
Oops, there I went again, being too general! Thanks, Bill. Stu
Old 09-20-2011, 03:04 PM
wilsel's Avatar
wilsel wilsel is offline
wilsel is starting off with a positive reputation.
Let us know what you decide. I've been on the hunt too.
Old 09-20-2011, 03:37 PM
brain75's Avatar
brain75 brain75 is offline
brain75 is gaining momentum as a positive member of FTE.
I wanted to stay as close to stock as possible... The PO in my case replaced the 16" split rim with 15" "outtie" nub - those, 15" outtie nub, are a dime a dozen, go to the junkyard and look at almost any truck for em (mark 8, grand marque and crown vic as well). Trying to get 16" and innie nub I struck out everywhere till I found Coker tire. Coker sells a brand "specialty wheel" that is a wider (they do sell a 4.5", but good luck finding tires for that) but otherwise looks right, they take beauty rings and moons even.
Hot Rod Steel - 16x6 Primed - Ford - OE Wheels - Wheels
Old 09-20-2011, 03:46 PM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Quote:
I run a set of original 16 inch wheels with a 4.5" bead width. Bought a set of Cooper LT 205/75/16's last summer from the local tire store. They do very well. No problems so far.
EDIT: I was wrong with the size. The tires are actually LT 215/85/16's. NOT 205/75/16's like I mentioned in this post. Apologies!!
Old 09-20-2011, 05:57 PM
brain75's Avatar
Mind naming names what's the store - I did look both locally and online (tires.com and tire-rack)... no love at all for 205 here in Denver... Just repeated the online search and still no love.
I do remind myself 80% of the US populace is in the eastern and central time zone, we mountain time zone folks are like red headed ******* step children...
Old 09-20-2011, 06:15 PM
wilsel's Avatar
Yeah we are, but living here is worth it.
Old 09-20-2011, 08:03 PM
jmadsen's Avatar
Quote:
3.5". Also 3.5" backspace.
Old 09-20-2011, 10:08 PM
Doc's Avatar
Doc Doc is offline
Oh crap. Apologies! I told you wrong. My truck (the one in the avatar) has Cooper Discoverer H/T tires size LT215/85/16. They are mounted on four original 16 inch rims with the narrow 4 1/2" bead width. They look good and they do very well. I'm quite satisfied. Again, apologies. I told you the wrong size earlier. I'm gonna edit that post above. I bought them at a local Ma and Pa Western Auto store.
Wheel Adapter Jumpdummy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 09-11-2012 08:48 PM
76 f100 bolt pattern wheel adapters? 77429highboy 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-31-2012 11:24 PM
wheel lug pattern sizes mejonz 1987 - 1996 F150 & Larger F-Series Trucks 4 11-03-2011 04:30 AM
wheel bolt pattern 50adrod 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 02-09-2011 06:48 PM
87 f 150 4x4 Is my wheel lug pattern 5 lug 5.5 bolt pattern? l67cooled 1987 - 1996 F150 & Larger F-Series Trucks 1 11-12-2009 09:51 AM
Tags
10, 11, 1979, 5x5, 5x55, carolina, drums, dump, f150, north, rear, rim, steel, truck, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
