2004 escape airbag light - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 09-15-2011, 03:23 PM
xc4jokestomper xc4jokestomper is offline
xc4jokestomper is starting off with a positive reputation.
my moms airbag light in her 04 escape is on. she hasnt hit anything and she has no idea why its on or what it means. is this a sensor going bad or what?
its an 04 ford escape 3.0, i think, auto.
Old 09-15-2011, 11:48 PM
5_labsownus's Avatar
5_labsownus 5_labsownus is offline
5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.
When you turn the key to the on position all of the dash lights are on for a few seconds and go out. Does the air bag light flash or stay on. If it flashes it indicates (by the number of flashes) what the basic code is.
From what I can see in the shop manual if it is on steady it may indicate the system has totally failed or there is no communication with the RCM.
Rod
Old 09-16-2011, 10:50 AM
She said when she turns it on it flashes 4 times then stays on constant
Old 09-16-2011, 11:08 AM
Nevermind it blinks 4 then 7 then stays on
Old 09-16-2011, 05:45 PM
flash of 47:
DTC
B1881 Passenger Pretensioner Circuit Open
and/or
B1886 Passenger Pretensioner Circuit Resistance Low
I would check the connector under the passenger seat.
Rod
Old 09-17-2011, 09:03 AM
Thanks for the response. Ill look at that and see whats up
Old 10-31-2012, 11:01 AM
Zousha Zousha is offline
Zousha is starting off with a positive reputation.
I have a 2004 Ford Escape that will beep 5 times in four sets, then goes quiet for a while, then starts up again. From previous forums I have read, this is a problem with the airbag warning light. No warning lights are showing up, but some of my instrument panel lights do not come on when I turn on my lights at night. Where exactly are these light bulbs located, and how hard are they to get to and replace? I would rather fix this myself instead of spending 200 bucks for a trip to the dealer just to swap out a light bulb. I will also check the electrical connections under the seats, but wanted to get a heads up on the instrument panel lights first. I do not get any backlights on the instrument panel show up on the bottom half of the panel, so I can't even read what some of the things indicate. I just got this vehicle used about a week ago, and I am trying to resolve the minor issues we had with it. I finally got the ignition coil misfire problem remedied, for now. Thanks for any help.
Doug
Old 11-12-2012, 09:25 PM
wastingas wastingas is offline
wastingas is starting off with a positive reputation.
look under the seat. driver and passanger theres a little harness the size of a zippo lighter. Squeeze it together, 90% chance it turns off ur light. I cut mine and spliced them together, bypassing the crappy harness's. keep us posted with the outcome.
Sometimes it helps to slide the seat forward to access it
Old 11-14-2012, 09:11 AM
Derding Derding is offline
Derding is starting off with a positive reputation.
x2 to what he said. Had the same thing with mine, easy fix.
2001 Ford Escape Air Bag light C1414 Flash Code 29 rweeks Escape & Escape Hybrid 7 05-17-2014 12:39 AM
03 Escape - airbag light code 21 truckh Escape & Escape Hybrid 1 04-29-2014 10:58 AM
Location of RCM in 03 Escape truckh Escape & Escape Hybrid 4 03-26-2014 12:01 PM
04 escape airbag code 37? rcgtsport Escape & Escape Hybrid 2 02-20-2014 08:54 PM
airbag light keeps coming on, xc4jokestomper Escape & Escape Hybrid 4 11-02-2010 11:57 AM
Tags
04escapecodeb1881, 1995, 2002, 2003, 2004, 2011, air, airbag, b1886, bag, escape, f150, ford, hybrid, light, stays
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
