Seat swap in '92 F150
Hey guys. I have been using info from the forum for sometime now. After adding a factory tach to my truck with direction from this forum I decided I needed to go ahead and sign up. Man the tach swap so simple I could have had my 6 y/o do it for. Thanks for the info.
Background: 1992 F150 XLT, Supercab, Bucket seats, 2wd, 5.8L, auto.
Question is: I found some seats from a '92 Lightning and was wondering will those bolt right into my truck? The Lightning seats look like they are bolted to a frame/riser then bolted to the floor. My factory buckets bolt straight to the floor. I am going to assume I would need to get the riser from the lightning.
Thanks in advance.
Jim
Thanks in advance.
Jim
Those Lightning seats do not come cheap unless the seller does not what they are. I have seen "L" seats and riser go for a couple hundred $$ more than a few times.
I have owned 2 different '93 L's in the past. Anything associated with them tends to raise the market value.
Jrock909
05-17-2006 03:49 PM
2000EXPORT
08-30-2003 11:29 PM
