Steering Stabalizer - Which One??
I'm looking at purcahsing a dual steering stabalizer, I've narrowed it down to either the Rough Country or Pro Comp, does anyone have any experience with either one, which one would you recommend? Is there a better brand out there that I may have missed,Rancho, Bilstein, etc..?
I'm basically looking for any recommendations.
Thanks in advance, look forward to reading your responses.
Stabilizer
rough country dual stabilizer and 3" lift-coming soon!!
i see this is an old topic but, i just ordered a dual steering stabilizer from rough country along with a 3" lift for my 2006 f250, hope it makes a big difference in the ride and the steering, i will be powder coating all the mounting brackets and new coil springs fire engine red, also i will be adding 35x12.5x20 nitto M/T's, i will post pics after i get it installed.
yea rough country was pretty cheap, but its got to be alot better that the wore out factory stabilizer that is on there now, plus my junk factory rancho shocks with over 100K on them are needing to be changed badly, i hope the Rc ones make a noticeable difference in the ride? i am installing this next week i will post before and after pics when i get it all done.
Installed a Skyjacker dual system on my SD/CC/4WD four years ago ... very satisfied.
https://www.ford-trucks.com/forums/8...alignment.html
I have the ProComp dual stabilizer set up on my truck, and I haven't been very pleased with it at all. The way the mounting bracket and shocks are set up cause the shocks to bind in such a way, that after a few months they start to leak. In the 3 1/2 years I've had them, I've had to replace the stabilizer shocks about 5 times so far. Luckily they have a lifetime warranty, so a get free replacements. I discussed this with the shop that installed my lift, and they said it was installed per mfg instructions. I even talked to some tech guys at procomp, and they even explained the installation process, and also sent me a copy of the installation guide, just to make sure it was on there right. After many different fine adjustments, the longest I've been able to to run a set of stabilizer shocks is about 11 months.
DSMMH
03-07-2020 07:58 PM
