brake line fittings
brake line fittings
I am redoing all of my brake lines on my truck ... because it made me do it (rusted through). Things were going well but I've run into a "fitting" issue. The line from the front right wheel that goes into the hydraulic control unit is a 3/16" line. The OD threads going into the controller are 5/16" but the flared-nipple inside the controller is sized for the 3/16" line. The old 3/16" line had the correct 3/16" flare to fit up well to the nipple but had the 5/16" threads to fit into the port. I bought a 3/16" to 5/16" adapter but as I was putting it together I realized that the adapter had a flare for a 5/16" connection and that it would not seat to the 3/16" nipple in the controller. Can anyone tell me what fitting I should look for and where I can get it?
My truck is a 99 f150 w/ 4-wheel disc, 3 channel abs
Thanks,
Mike
Thanks,
Mike
Thanks for the note. I need to do the same in the near future. If I may summarize your note, I would need a special fitting.
It sits between 3/16" OD flared (double flared?) tubing and 5/16" threaded port of the controller (pipe or straight thread?). Since the flared end of the tubing has a B-nut, the special fitting has a straight thread for the B-nut, I suppose.
Am I correct?
Thanks.
Am I correct?
Thanks.
Parker,
This link Differences in Brake Line Fittings | eHow.com has a good illustration of what my problem is. My problem isn't a metric / standard fitting issue but rather a small / large fitting (thread) for 3/16" line. I'm not sure what a B-nut is so I cannot comment on that. I've had to reuse a couple of my fittings as Napa didn't have enough to go all new. I've had to drill one out and I was successful in lightly pounding the line out of another. I still am not sure what I'm going to do (if anything) about the 2 lines that go from the booster to the hydraulic control unit ... they have steel tube on the ends with flex line in the middle. This is because the booster is mounted to the body and the HCU is mounted to the frame. The flex allows for body flex & twist. I cannot find replacement line like this anywhere. I'm thinking about putting a good size loop in these lines to allow for the flex but I'd like to get some input or feedback. These lines are also quite rusty so I'd really like to change them now, while the system is empty of fluid.
Any feedback is welcome !!!
Mike
Mike
pace car
09-30-2012 04:11 PM
Pele
06-02-2007 09:21 AM
