brake line fittings - Ford Truck Enthusiasts Forums
brake line fittings
Old 09-15-2011, 11:16 AM
Mike-G Mike-G is offline
Mike-G is starting off with a positive reputation.
brake line fittings
I am redoing all of my brake lines on my truck ... because it made me do it (rusted through). Things were going well but I've run into a "fitting" issue. The line from the front right wheel that goes into the hydraulic control unit is a 3/16" line. The OD threads going into the controller are 5/16" but the flared-nipple inside the controller is sized for the 3/16" line. The old 3/16" line had the correct 3/16" flare to fit up well to the nipple but had the 5/16" threads to fit into the port. I bought a 3/16" to 5/16" adapter but as I was putting it together I realized that the adapter had a flare for a 5/16" connection and that it would not seat to the 3/16" nipple in the controller. Can anyone tell me what fitting I should look for and where I can get it?
My truck is a 99 f150 w/ 4-wheel disc, 3 channel abs
Thanks,
Mike
Old 09-15-2011, 11:17 AM
BTW, I've tried to reuse the old fitting but it is either all one piece (line and fitting) or is so rusty that I absolutely cannot get it apart.
Mike
Old 09-15-2011, 02:19 PM
Never mind - no need to reply. I took one of the old ones into NAPA and they had exactly what I was looking for. Other brand stores did not, which is why I posted.
Later,
Mike
Old 09-15-2011, 05:57 PM
paker paker is offline
paker is starting off with a positive reputation.
Thanks for the note. I need to do the same in the near future. If I may summarize your note, I would need a special fitting.
It sits between 3/16" OD flared (double flared?) tubing and 5/16" threaded port of the controller (pipe or straight thread?). Since the flared end of the tubing has a B-nut, the special fitting has a straight thread for the B-nut, I suppose.
Am I correct?
Thanks.
Old 09-16-2011, 07:30 PM
Parker,
This link Differences in Brake Line Fittings | eHow.com has a good illustration of what my problem is. My problem isn't a metric / standard fitting issue but rather a small / large fitting (thread) for 3/16" line. I'm not sure what a B-nut is so I cannot comment on that. I've had to reuse a couple of my fittings as Napa didn't have enough to go all new. I've had to drill one out and I was successful in lightly pounding the line out of another. I still am not sure what I'm going to do (if anything) about the 2 lines that go from the booster to the hydraulic control unit ... they have steel tube on the ends with flex line in the middle. This is because the booster is mounted to the body and the HCU is mounted to the frame. The flex allows for body flex & twist. I cannot find replacement line like this anywhere. I'm thinking about putting a good size loop in these lines to allow for the flex but I'd like to get some input or feedback. These lines are also quite rusty so I'd really like to change them now, while the system is empty of fluid.
Any feedback is welcome !!!
Mike
Old 09-18-2011, 07:58 AM
Dave G. Dave G. is offline
Dave G. is gaining momentum as a positive member of FTE.
Mike
Just Google "stainless steel brake lines", lot's of choices.
Dave
Old 09-18-2011, 12:04 PM
usafstud usafstud is offline
usafstud is starting off with a positive reputation.
Quote:
Originally Posted by Dave G. View Post
Mike
Dave
i been having trouble finding SS brake lines for a 4x4
Old 09-18-2011, 05:05 PM
Woo Hoooooo. Brake lines are done. All lines and hoses are NEW. I fixed my parking brake since I had everything torn apart. Good feeling!!!
Mike
Best flaring tool comprimise 4DB 1987 - 1996 F150 & Larger F-Series Trucks 26 06-08-2016 05:07 AM
96' F350 non dually rear brake line cityjack 1987 - 1996 F150 & Larger F-Series Trucks 13 04-07-2016 08:45 PM
86 f150 rear brake line fitting size rustfreemike 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 03-31-2014 08:41 AM
What size brake line do I need? fabsroman Brakes, Steering, Suspension, Tires, & Wheels 5 07-19-2013 09:44 AM
Fixed 99 XP rusted rear brake lines orleec 1997-2006 Expedition & Navigator 11 08-14-2012 09:12 AM
Tags
1997, 2003, adapter, brake, brakeline, f150, fitting, fittings, ford, kind, line, scamatic, sizes, standard, trucks, tubing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
