When should i upgrade HPOP???
right now i just have the 6637 intake and 3" dp for mods, then i'm adding gauges and i want to do a chip, then stage I's... all that being said, at what point should i do the HPOP? should i just wait for it to go out, or should i get it before it gets me? also, what is a good one to go with?
thanks in advance!
thanks in advance!
The stock HPOP may serve you just fine with Stage 1's. If not, I would recommend the T-500 from Terminator Engineering. It is a very cost effective upgrade over the stock HPOP and if my stock HPOP ever fails, that's what I will be getting.
Others who have first hand experience with this will chime in soon, but my understanding is that stage 1's will run fine with a healthy stock HPOP.
Don't get in a rush, but start hunting for a spare HPOP and send it to Joey at Terminator Engineering to get made into a T500. It will feed those 1's nicely and the price is very reasonable. If you can deal with having your truck down, just send him the pump you have.
Joey has a great pump but you will be fine for a while.
You could even upgrade to a SD pump for cheap if you can find one. That should do you fine. As long as it is a good working truck.
When you need a pump is when your duty cycle goes up alot and the pressure drops off quite a bit. A graph shows it well. Get someone with AE or a scan gauge and take a look at it. You may already need a pump and not know it yet.
Daniel FWIW I'm running stage 1's with Tyrant tunes and a stock 15° pump (haven't got my modded 17° installed yet) and I had to hold it too the floor for quite a while in my extreme tune to trip the SES light. You'll be more limited by EGT's than by HPO.
I've been driving on my Stage 1's all summer like a raped ape and I have yet to throw a CEL. Towing and empty. I have a nice healthy engine (touch wood!) with only 122k miles, but I am still planning on the HPOP upgrade. It's just something worth doing for the piece of mind.
I've seen the SRP1 locally for $500, but I am probably going to just go with a SD pump unless I can find a spare to send to Joey. Reliability is the most important factor for me. Power is 2nd.
