Fog light bridge harness for OEM to PIAA ?
OK, sorry for the confusing subject line....
Does anyone know of some kind of wiring harness adapter/bridge that I could use to hook the OEM fog light wiring harness (the end that used to clip right to the base of the bulb) to a PIAA harness?
I extracted my OEM fog lights today and ordered some new PIAA Xtreme fog lights to replace them. My lazy brain tells me I want to keep my OEM dash switch to operate them and re-use the existing wiring so as to make this as painless as possible upon install. The PIAA's aren't HID or anything that would draw more current than the OEM lights did, so I think I am safe not needing new wiring or a relay here.
Any pointers much appreciated guys! Otherwise, I will splice and dutifully wrap up the graft in tape or such to keep the water and crud out.
OK, seems this harness "vision" that I had is not easy to find (PIAA does not make one either... I asked them), but I do have a deeper question:
Can the OEM wiring handle a 55 watt-per-light draw for my new fogs when I install them, or will I end up needing to run new wires and install the relay PIAA supplies anyways?
haroutd? others?
Thanks for the replies guys....
haroutd? others?
Location: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
on
1 Post
I don't remember the wattage on the stock fogs, but I can tell you that running a direct route using PIAA's hardware will guarantee that your lights emit maximum lighting. In short, you can get away with using the stock wires, but you might notice a slight difference if you use the kit it came with.
The relays & wires came with the PIAA's, so you're not spending any extra cash on them anyway... might as well put them to use! Yes, I know it's a slight pain in the neck, and it will eat up a little time, but you're only looking at 2-3 hours, and you only have to do it once. I'm a big proponent of going as overkill as possible, so my advise is to use what PIAA gave you. Again, you can probably get away with OEM wires, but I wouldn't do it. If you decide to use the OEM wires, ditch the harness idea & get some of those little crimp-on wire ends (forgot their real name -- it's late, you know). Just remember to wrap a piece of electrical tape around to keep it clean, too. This way it's easy to disconnect everything when you decide to try running the wires the "right" way. Or you can just pick up some heat shrink wire tubing from radio shack instead of taping your splices.
PS -- Ever think of leaving the OEM fogs alone & running the PIAA's in addition to them? The more light the better!
Now, you got me thinking.... maybe I replace the OEM fogs in their low location with some regular (read: more like stock) wattage lights and mount the PIAA 2192's up in the grill, aiming low, like I was planning.
hmmmmmm........
Bob, I'm so dissappointed you bit the PIAA bug. Kidding...think the OEM fog lights are 40 or 45 watt. I've been using 65 watt replacements for awhile, and haven't had any problems with the stock wiring, relay, etc. I looked for a factory type harness when I was searching for replacement lights...couldn't find a thing. If you need to cut and splice, look for some heat shrink tubing at any car store or electrical shop. If you strike out, send me your address via private message and I'll send you some. I can get either blue or black. Still serving in A**-Crack-a-Stan...
Bert
Bert
