2000 F350 Cruise Control stopped working
mine broke last fall...same thing...no cruise. i just unhooked the switch from the pedal assembly and made some jumper wires and wired the switch to act as if it was ok. i zip tied it out of the way and all has been fine since. but must be careful, because the truck WILL start without the clutch pedal pushed down. no biggie since im used to manuals, rule of habit to press in the clutch anyway. good luck
i can get pics after work...but what i did was disconnect the switch...it is a large black cylinder on the clutch pedal...mounted at the firewall on the actual shaft. when i took mine out, it was clear to see that a spring was pushed in/out and contacts were connected or disconnected. i used small wires with male flat blade ends and jumped the actual wire connection in the truck. a little electrical tape, and all has been good. make sure you jump the connections on the wiring in the truck, not the switch itself. i think i threw the switch away...i can get pics but they will be tough to see because of where it is at...i think there is a link for it also...ill check
ok I need a hand if someone can help, the previous owner must have pulled the sensor off the clutch pedal I've searched high and low and theres no CPP and yes I know what it looks like, I think I might have found the harness that went to it though, there is 4 wires that have been taken out of a pigtail and two he twisted together, I think the superduty 7.3l diesel manuals only had 4 wires going to the sensor
I have 1 white wire with pink stripe in it
1 blue wire with a yellow stripe
1 red wire with a yellow stripe
and I cant really tell the 4th wire
theyre all dirty and I'm somewhat colorblind(please dont rip on me) so take the colors im giving with a grain of salt, oh also they all look to be the same size wire gauge
