Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 5.0L Coyote
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
  #1 (permalink)
Old 09-15-2011, 02:08 AM
svt2205 svt2205 is offline
Garage is empty, add now
svt2205 is gaining momentum as a positive member of FTE.svt2205 is gaining momentum as a positive member of FTE.
5.0 Unexplainable Mis
I'm curious does anyone else with a 5.0 F150 have a mis between 1200 and 2000 rpm? Mine does, 2 dealers wont help me. Even after noticing "something" during a test drive with me, they are not able to repeat it on their own nor does it show any code nor will they do anything about it.
Any suggestions? The truck only has 12K on it. Sadly, it's not been a very good F150. Oh well, bad vehicles are built and I own one...
__________________
2011 FX4
  #2 (permalink)
Old 09-22-2011, 10:51 PM
AdamTN AdamTN is offline
2011 Ford F-150
AdamTN is starting off with a positive reputation.
I noticed a bit of a miss with my truck at well it seemed to be between 1200 and 1500 rpms and I didn't notice it when the a/c was off. I took my rig in last week to get the "stretchy" a/c belt and tensioner because it was making a knocking sound at idle. Since then, I haven't noticed the miss. So I'm not sure if they were related... It was a small miss and otherwise the truck is running great!
  #3 (permalink)
Old 09-26-2011, 06:40 AM
640 CI Aluminum FORD 640 CI Aluminum FORD is offline
2011 Ford F-150
640 CI Aluminum FORD has a very good reputation on FTE.640 CI Aluminum FORD has a very good reputation on FTE.640 CI Aluminum FORD has a very good reputation on FTE.640 CI Aluminum FORD has a very good reputation on FTE.
I cant say i've experienced it with my 5.0L mine just rolled over to 5,000 miles yesterday and its been trouble free so far.
Anyway, if you find out what it is let us know. And good luck.
  #4 (permalink)
Old 10-03-2011, 06:49 PM
Well I have given up with the local dealers. They offer no help. I pulled the plugs and found 2 that look worse then the others. I've replaced the plugs with a new set of motorcrafts and replaced the 2 cops on those. Seemed to improve things for about 200 miles, now the condition is back. Now thinking the injectors on those cylinders may be firing with a poor pattern. I'll try a couple new one's to see if that does anything. I've got no codes and my autotap software offers little in direction towards finding the cause. So, it's try this and try that time.
I will say, after the 5.4 3V plug change challenge, Ford did a nice job with these. It takes a couple minutes per plug to change.
If this doesn't work, I've been test driving some nice 11 super duties. So, I may just say the heck with it and buy a real truck. One that I can plow with.
__________________
2011 FX4
  #5 (permalink)
Old 01-02-2012, 04:18 AM
Gary Vincent Gary Vincent is offline
Gary Vincent is starting off with a positive reputation.
i have a 2011 F150 5.0 king ranch it uses 1q oil every 1000 miles has any one else had this problem
  #6 (permalink)
Old 03-19-2012, 09:57 AM
Fireman81 Fireman81 is offline
Fireman81 is starting off with a positive reputation.
I had a miss type situation or a shudder but at around 1000 rpm's. 300 miles on the truck. I asked a mechanic at my dealer and he said that he was told by ford that the modules that communicate with each other can hiccup from time to time. My suggestion to you though is that if it is a constant issue make them check into it.
  #7 (permalink)
Old 03-20-2012, 04:09 PM
04XLTRUNNER's Avatar
04XLTRUNNER 04XLTRUNNER is offline
2012 Ford F150
04XLTRUNNER is gaining momentum as a positive member of FTE.04XLTRUNNER is gaining momentum as a positive member of FTE.
1800 miles on my 2012 and no problems, plugs fire fine and oil level is fine. This weekend is Fun Ford Weekend at Royal Purple Raceway in baytown so ill be getting the PCV filter canister
__________________
2012 Lariat SC 4x4 5.0. Tuxedo Black, 3.55 E-lock,6.5" MacGaughy Lift, 1.5" AAL, 20" XD Cranks w/ 35" Fuel M/T Rubber, 5Star Tuned, Blacked out upper/lower Grille,Cherry Bomb,Spyder CCFL Halo Projectors, HID's, Full Int. LED, LED 3rd Brake & Taillights, Fire&Ice Bar, LED puddle lamps
Gone:2009 F-150 FX4, 2005 F-150 lariat 4x4 & 2004 F-150 xlt 2x4
  #8 (permalink)
Old 07-29-2012, 12:31 PM
ChargersFanInCO ChargersFanInCO is offline
ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.
Quote:
Real truck, huh? If you want something that'll cost you an arm and both legs every time something goes wrong with it, then yes, a Super Duty is the best truck for you. I just got rid of my 2009, 6.4. 138,000 miles on it, and out of the blue, with no codes, it needed a DPF, DOC's, EGR Cooler, Turbo, Head Gasket, and an aluminum timing cover that got ate by the lovely gold coolant Ford uses, even though the nitrates were perfect.
Buy one and report back in 50k and tell us how the HPFP and DPF are doing. That 6.7 has issues, too, so don't be fooled. Now if you meant a gasser Super Duty, well, that's just a frame upgrade over an F150...Still not a "Real Truck"...
I'll never buy a new diesel again.
400 miles on my '12 5.0. 19.6 miles to the gallon, and I'm loving it.
Tags
1000, 2011, 50, engine, f150, find, mis, noise, rpm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
