rev-x or hot shots..
#31
#33
on
Anyone have any idea what's in HSS? I've never touched it/tested it. Based on the above I'm guessing some sort of heavy dose sulfonate? HDEO already has a higher than normal dose of detergents and dispersants due to it's inherently dirty nature (soot/etc...) so I wonder what/why HSS has in it as it doesn't make much sense to just add more 'pack' to an already high level 'pack' oil (maybe why it doesn't work???). Anybody have a few ounces they could send me?
Stay away from the blue diamond threads though unless you want some entertainment.
Originally Posted by Zmann
IDK but you get your money back
#34
I don't agree .. but not arguing
I had a slight stumble when I ordered my HSS but before I got it I had a second one fail and had to go to the dealer
it didn't hurt the truck to drive but you wouldn't want to drive it far .
so if u try the HSS or Rev-X for a stiction issue I don't see the problem if it doesn't work
your other choice is new injectors for thousands of $$ or at least 1 or 2 plus diagnostics for
what ?? $900
Man this site is slooooow
#35
on
The fact that there are people that tried it and it didn't work and they had injectors that were still operating, contrary to the quote that you had that it would fix injectors even those that weren't operating.
That's a claim that even if true is one that shouldn't have been made just to cover their own butt incase for those statistics of one to where it nailed them.
Just like their high claims for the blue diamond engine oil.
Depending on the case, you could actually rebuild them. It would just depend on the situation. That's a little bit of a false dilemma.
#36
As you Know you can't rebuild them yourself
you can only buy remans or aftermarket and they are all rebuild able unless physical damage has occurred
so I am not hearing what you recommend in this situation even though the OP 's? was what product was better ?
HSS No
rev-x No
replace injectors if they are down on contribution yes?
HSS No
rev-x No
Last edited by Zmann; 09-18-2011 at 07:19 PM. Reason: added Know to as you can't rebuild (deleted by accident originally)
#37
HSS' info is pretty bland. They kind of 'kitchen sink' what they say is in there: http://www.hotshotsecret.com/Assets/...ech%20data.pdf
So not much to go off there. Should be interesting to see what it's really made from.
P.S. I didn't realize it's $50 for a two Qt bottle, that's $100/gallon!!
RevX is $1120/gallon LMFAO! <--considering what's in it that's a SICK margin and when you consider that almost 75% of it is just filler and pure mineral oil you can't help but laugh even harder. [128/4=32treaments/gal ($35)/treat= $1120/gal]
#38
on
But that's just me. I will also add this caveat, I'm not much on additives in general, so I do have that prejudice already in my mind.
#39
About a year or so ago, we had Chris (something or other) and his salesman(supertruck60) on here and there was some heavy back and forth between Chris and beachbumcook. It might have gotten mentioned in those threads.
Stay away from the blue diamond threads though unless you want some entertainment..
RevX threads are becoming quite entertaining as well (probably my fault).
EDIT: tex here's the HSS thread you mentioned https://www.ford-trucks.com/forums/6...ditive-11.html
Wow this guy 'Chris Gabe' apparent owner of HSS is an absolute lier on page 17 he says:
The additive we use in the HSS are not the same as those used in a motor oil. Blackstone is looking for traditional additives phosphorus, zinc, etc. Lubrizol and other additive companies blend those adds and test them, then they offer them to Exxon, Shell and others. They can chose ad pack 111xyz or 222yby etc depending on the base oil they are using and the price point they are trying to achive. We are not in that arena with this product. We are starting with base chemicals and building up.
More lies page 23:
You don't just submit a product or paperwork to CAT, International, Deere, etc... First you spend your companies capital about $90,000 to have your additive tested THEN you can submit it to X,Y,Z company but they are just going to trashcan it anyway because they already have agreements with the major oil companies like Chevron/Shell/etc.. Think about it, why would a company like International spend their money and time testing your home-brew additive at considerable cost that they don't need in the first place and if they felt as though they needed one they would have Chevron/Shell/etc. make one for them that is tested and is backed by a major company than sold through Ford... Now lets just say you wanted your product to be approved for use through CAT, International, Deere, etc. they don't do this on a whim, it has to be tested (my area) and the company wanting this approval has to pay for said testing, about $90,000 then there is all kinds of licensing agreements and mountains of other BS.
Here's another: http://www.powerstrokenation.com/for...t=50272&page=2
#40
#43
Here is one aftermarket injector for example (not saying they are bad or endorsing // not to mention all the bogus cores floating around that are none functional
Industrial Injection "New" 6.0L Powerstroke Injectors
#44
It appears I have one injector that is a little sticky. I have a stumble that lasts only for a few seconds when I go to take off the first time in the morning. Then my truck runs fine.
I had wondered about Sea Foam.
Please tell us how much Sea Foam you used, how long you left it in, and what your truck was doing before the sea foam treatment.
Please give us some more details about what worked for you.
#45
Mine was "missing" while pulling the 5th wheel just before the peaks of the hills between MD and NY going up I-81 in PA. Didn't matter if I was in or out od Tow/Haul. If I did pull it down into a lower gear, it would stop tho.
I bought 3 cans. Waited until about 100 miles before I was going to do an oil change and pulled the upper fuel filter and sucked all the fuel from the bowl. Stuck the filter back in and filled the bowl with the SeaFoam. Poured the rest of that can and 1/2 of the 2nd into the fuel tank (which was full).
Poured the rest (one and 1/2 cans) into the oil filler on the engine and drove it about 100 miles and changed the oil. By the time I had gone thru that tank of diesel it must have "cleaned" the injectors 'cause it quit "missing" when I pulled the trailer the next time! The "miss" I was experiencing felt exactly like a gas engine missing caused by a bad plug.
It's been over a year now and I did feel that once since then. Same thing - was towing RV in the mountains- I always use Power Service (grey in summer) but had NOT put it in on that tank of fuel. I put it in next tank and all was well again.
