Possible to weld on valley pan???
Hey guys, I am at my wits end here with my banks drain tube leaking oil where it enter the valley pan. I have replaced the grommet 2 times and it still starts to leak within a couple months!! I am considering welding a hose barb onto the valley and then connecting a hose to the drain tube. Any thoughts on this, has this been done before, any tips on welding on it, is the valley steel? My brother said it would be too dangerous to do it while it is on the engine.
Thanks so much!
Thanks so much!
Brazing would be best. Off of the engine. If you can't braze it might be a hose barb with a 1/4 NPT male end, sealed with silicon, through a hole drilled in the valley pan and secured on the other side by a brass 1/4 NPT connector would work. Oh, and the pan is steel. About 12 or 14 gauge I would guess, real thin stuff.
I would say it'd be quite easy to tig weld on a hose barb. A tad more challenging for a mig or stick though of course, so if you don't have tig I'd recommend brazing. I've tig welded 3/16" brake line to a 1/2" bolt. (Needed to rig it up to pass an emissions inspection heh) If you weld it on it doesn't even have to be much of a hose barb really, you could tig a steel tube to the valley pan and tig weld a small bead around the end of the tube to keep the hose clamped on.
I must have been lucky with reusing my old grommet. Cleaned it all up real well, set it in place and then filleted over the grommet/pan/drain with RTV ultra black. No leaks from it.
Can't see why the trouble. Are sure you don't have a split in the drain tube somewhere? If you follow Banks directions you shouldn't have a problem. The area needs to be clean of oil and debris. Install the grommet then the tube. Then coat a liberal amount around the drain tube and grommet. Allow to dry. Did you punch some holes in the bottom of the drain hole in your valley pan when you installed the turbo so the oil can drain fast enough?
on
EDit: in general, I've had good luck with permatex ultra black. I've never tried it in this scenario.
on
i always opt for ultra black whenever oil is involved.
i have each of these coming actually right now to prepare for my banks install:
http://www.amazon.com/gp/product/B0002UEN1U
http://www.amazon.com/gp/product/B000HBNUDQ
i used the black on the rear axle for example.anywhere you want to protect against oil.
on
could be.looking on permatex website,it looks like the copper is about the same as the black,but the copper withstands gasoline where the black doesnt.
edit,
well i dunno.look at each there.it appears the black they recommend for high oil resistance applications and the copper for use with gasoline resistance applications.
i think i'll be using the black there (the stuffs' never failed me,so why question it now anyway lol.)
edit,
