Head Gasket on a 360 - Ford Truck Enthusiasts Forums
Old 09-14-2011, 09:56 PM
Tedybear Tedybear is offline
Tedybear is gaining momentum as a positive member of FTE.
Fast question:
Working out all the issues with our 360:
I noted they offer a head gasket..and a head spacer.
Main question: What is the purpose of the spacer in relationship to the gasket? Is it always needed, optional, etc... If I have to pull the right head off the engine to repair the exhaust problems on that side...I need to know if it is required to use both a spacer (and how it goes in) with the gasket.
Thanks!!!
S-
Old 09-15-2011, 07:51 AM
FFR428's Avatar
FFR428 FFR428 is offline
Needsmorecoffee.
FFR428 has a good reputation on FTE.FFR428 has a good reputation on FTE.
There are 2 (on each side 4 total) metal O shaped dowels that lineup the head on the block. Is that what you mean by spacers? If so then yes you need them.
Old 09-15-2011, 07:53 AM
FFR428's Avatar
Needsmorecoffee.
Forgot to add they just push in by hand.
Old 09-15-2011, 08:44 AM
Those would be the dowel pins or guide pins.
When I look up the head gaskets at Napa or Advance auto they list two. One is an actual head gasket and the other is a head gasket spacer shim
Felpro Head Gasket Spacer Shim
Part No. 8554 SP
Felpro Head Gasket
Part No. 8554 PT
Felpro Cylinder Head Alignment Dowel Pin
Part No. ES 74007
Now I know what the dowels pins are used for
Question is? When I pull the cylinder head to repair the exhaust manifold bolts and all that fun jazz...what is the purpose behind the spacer shim--and is it always used, and if so--How? (I've worked on newer engine heads in the past, never one that used a spacer shim)
Just trying to save a buck where possible. If I do not need the part, it's not going to get replaced. Or is this the case of not knowing if a spacer is used until I rip it apart?
Best Regards-
S-
Old 09-15-2011, 08:58 AM
FFR428's Avatar
Needsmorecoffee.
8554 sp is the copper head gasket. Like the old OEM steel shim gaskets. You just need the std head gaskets unless you need to bump compression up. You don't use both together. Does not say what tyhe thickness is on the copper gaskets but the oem steel shim are around .015 to .016 on stainless.
Old 09-15-2011, 10:40 AM
Quote:
Felpro Head Gasket
Part No. 8554 PT
Not needing extra compression. (that old gal runs pretty decent, considering the last owner ran it for a longgggggggggg while with a blow fuel pump dumping gas into the oil)
So the 8554 PT should be the only gasket I'll need, along with the exhaust manifold gaskets once I get the cob-job repaired.
This is going to be 'Fun'..... (NOT.....) (Ok...Sure..it's a ford..it's not work it is therapy)
S-
Engine Compatibility sam.tucker11 1967 - 1972 F-100 & Larger F-Series Trucks 8 11-11-2015 01:08 PM
FE 360 Head Questions Mister_King FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 01-26-2015 06:32 PM
need to find heated carb spacer cowboyfordlord 1967 - 1972 F-100 & Larger F-Series Trucks 11 12-03-2012 09:17 PM
360 with 429 heads ???????? 68 f250 1967 - 1972 F-100 & Larger F-Series Trucks 19 03-27-2012 08:27 AM
03 Explorer V6 valve cover gasket install question Sock Monkey Explorer, Sport Trac, Mountaineer & Aviator 2 08-04-2010 05:52 PM
Tags
1973, 1975, 360, 360t, 8554, blown, cylinder, engine, felpro, ford, gasket, head, replace, sp, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
