Headliner on the cheap. - Ford Truck Enthusiasts Forums
Old 09-14-2011, 06:14 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Well got tired of driving around without a headliner. So I went to home depot and bought a 1/8" sheet of hardboard. Cost $8.00. I just used my old crusty headliner for a pattern.
Traced it with a sharpie and cut it out with a jigsaw with a metal blade.
The metal blade is important it has smaller teeth and won't shred the hardboard.
Next I went to Joann's fabric and bought one yard of black marine grade vinyl. Cost $14.99 a yard. 1 yard is just enough to cover it width wise as long as it's a 54" width.
I wiped down the boards smooth side and laid the vinyl upside down sprayed both sides with headliner spray $19.99 a can. Let it sit for a min put the board flat side on top of the vinyl and laid the board down. Patted the back of the board to make sure it stuck.
Flipped the whole thing over then went over it with a rolling pin. After letting it sit for about 1/2 hour I trimmed the excess vinyl off with a razor blade.
After that I installed her. I still have to buy new screws but she's up and looks damn good for $42.98. I also think it looks way better then the factory style repop ones that are $90.00 plus $60.00 to ship.
Old 09-14-2011, 06:30 PM
Mexican77's Avatar
Mexican77 Mexican77 is offline
Mexican77 is starting off with a positive reputation.
Congrats, that headliner looks very nice and you canīt beat that price, but is easier when you have regular cab, with Supercabs thereīs no other way than going to the junkyards because of the size
Old 09-14-2011, 07:08 PM
co425's Avatar
Quote:
I disagree. The hard board is 4' x 8' and the vinyl is 54" wide x 10'. I think you could make that work as long as you have an old headliner to use as a pattern.
Old 09-14-2011, 07:22 PM
evam350 evam350 is offline
evam350 is starting off with a positive reputation.
Looks good but I'm just wondering how it added up to $42.98 when you said the hardboard was $8.00 and the fabric was $15.00?
Was the adhesive that expensive?
Old 09-14-2011, 07:27 PM
dakonthemountain dakonthemountain is offline
dakonthemountain is starting off with a positive reputation.
VERY nice job! Kudos to you for your ingenuity!
Dak
Evam350, He stated the spray was $19.99, so that with $14.99 for the fabric and $8.00 for the hardboard comes to $42.98 with no sales tax.
Old 09-14-2011, 07:32 PM
79bad4d's Avatar
79bad4d 79bad4d is offline
THE BEAST
79bad4d is starting off with a positive reputation.
That looks great....another project for me to do nice!!!
Old 09-14-2011, 07:41 PM
oops I missed the part where he said the spray cost $19.99
Old 09-14-2011, 07:44 PM
79_effie's Avatar
79_effie 79_effie is offline
79_effie is gaining momentum as a positive member of FTE.
Looks good man!
Old 09-14-2011, 07:55 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
What ever he used is better than a can of wally world 3M stuff......do not waste your money. If it sticks, its worth the almost 20 he spent.
Looks nice, thanks for the info on the items used.
Old 09-14-2011, 08:01 PM
co425's Avatar
This is what I used. They sell it at joanns too. It sprays just like the industrial adhesive my dad used to use at his shop. Like snot in a can. It sticks pretty damn good.
Old 09-14-2011, 08:57 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Nice work. Thanks for the materials list, costs, and methodology. I am motivated!!!
Thot I'd add my $0.02 is any of yall wanna add a custom touch. Buy 1/4-inch thick high density foam and lightly attach it with 3M Spray Mount (it's a light duty contact cement). Spray only one side!!!
Now sketch out or transfer your pattern (flames, diamonds, Ford logo, "FTE" or whatever you want) to the foam and cut out the low spots with a razor blade. Angle/bevel your cuts down to the hardboard because vinyl does not like to turn 90 degrees. Trace the silhouette of the piece on the board and remove the foam and reattach permanently. I work on only half of it at one time so it is easier to re-register on the tracing.
Apply contact cement like co425 and roll on the vinyl slowly while pressing it into the low spots ("reliefs"). Reinstall.
Old 09-14-2011, 09:26 PM
supercabfreak's Avatar
supercabfreak supercabfreak is offline
supercabfreak is starting off with a positive reputation.
how much more dificult could that be for a supercab...? my only problem is i dont have a old one to trace
Old 09-14-2011, 10:04 PM
flatcatnightmare's Avatar
flatcatnightmare flatcatnightmare is offline
flatcatnightmare is starting off with a positive reputation.
Very nice work !!! Even if it would have cost what the aftermarket ones do you can say you made this yourself , well done buddy !!
Old 09-14-2011, 10:23 PM
79F150Seattle 79F150Seattle is offline
79F150Seattle is starting off with a positive reputation.
Looks really nice. I am going to do the same for mine. I appreciate the list/cost like HIO said.
Old 09-14-2011, 10:28 PM
modularF100's Avatar
modularF100 modularF100 is offline
modularF100 is gaining momentum as a positive member of FTE.
Looks awesome, mang!
Dash Bezel silver trim how to co425 1973 - 1979 F-100 & Larger F-Series Trucks 54 06-27-2016 12:47 PM
70's roll bar upgrade co425 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-17-2015 08:05 AM
Mounting a Saginaw box on a highboy co425 1973 - 1979 F-100 & Larger F-Series Trucks 19 09-22-2014 03:09 PM
Definition MALL CRAWLER! co425 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-11-2012 12:54 AM
Update on Benchwork steering conversion co425 1973 - 1979 F-100 & Larger F-Series Trucks 13 10-04-2012 04:59 PM
Tags
19731979, building, buy, cheap, f150, fabric, ford, hard, head, headliner, headliners, laredotx, liner, making, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
