Headliner on the cheap. - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 01-19-2014, 12:16 PM
petrovich79f250's Avatar
petrovich79f250 petrovich79f250 is offline
petrovich79f250 is gaining momentum as a positive member of FTE.
[IMG][/IMG]
i took took 1/4 inch lawain plywood, traced my old headliner and cut it out.
then i took foam headliner material my dad had left over from when we did a headliner in his 1980 buick lesabre and used 3m spray adhesive to stick it to the plywood.
then i went to my local farm shows and county fairs till i found a confederate flag... we used the 3m spray adhesive to aply it as well... looks pretty good if i say so myself...
  #47
Old 01-19-2014, 05:32 PM
AlexAU AlexAU is offline
AlexAU is starting off with a positive reputation.
Hey, these all look really good!
Does any one know if anyone makes a reproduction of the chrome trim? Or if it has to come off another truck?
My truck didn't come with any of it...
  #48
Old 01-19-2014, 06:34 PM
gatorfor88's Avatar
gatorfor88 gatorfor88 is offline
gatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputation
LMC offers the trim for headliner.
  #49
Old 01-19-2014, 06:39 PM
Thanks Gator, will check it out.
  #50
Old 02-04-2014, 10:01 PM
notthemaniusedtobe's Avatar
notthemaniusedtobe notthemaniusedtobe is offline
notthemaniusedtobe is starting off with a positive reputation.
I just today bought a couple of yards of tan vinyl for my headliner to do this exact job, (I plan to tackle the dash top with the same stuff later). I was gonna re-vinyl the original backing board.
When I removed the old headliner I found that the board is a bit thinner than 1/8" hardboard, and warped to hell, so I'm gonna replace that, I also notice that the board is curved at the edges to follow the contour of the roof.
A couple of questions:
1. Is the 1/8" thick hardboard flexible enough to bend to shape at the edges and be held in place just by the chrome trim? Or should I try to figure out a way to pre-form the hardboard before attaching the vinyl?
2. As it is slightly thicker than the original, was it securely held in place by the trims without gaps?
Help appreciated, thanks.
John
  #51
Old 02-04-2014, 10:22 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
1. Yes
2. Yes
It's stiff board but will contour to the proper shape. You will not need the center screw. It is stiff enough to stay put.
  #52
Old 05-29-2014, 04:21 PM
Papas66's Avatar
Papas66 Papas66 is offline
Papas66 is starting off with a positive reputation.
Any tips on tracing a warpped old headliner on to the new board?
  #53
Old 05-29-2014, 04:22 PM
Papas66's Avatar
The picture doesn't show how deformed it really is.
  #54
Old 05-29-2014, 04:23 PM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
What I did was lay mine down on the new board and spray painted around it to give me an idea (outline) of the shape I needed. I cut it a little big and then trimmed until I had a good fit.
I had posted this in the "what did you do to your truck today" thread a while back when I did it, but I'll copy it here too.
Redid my headliner. with 3/16th hard board and vinyl from Hobby Lobby.
Old headliner
New headliner cut into shape
Factotry insulation on roof.
New Headliner covered with some batting and vinyl.
Installed!
  #55
Old 05-29-2014, 06:52 PM
co425's Avatar
Quote:
Just weigh it down with something to flatten it out. Worked for me.
  #56
Old 10-04-2014, 08:17 PM
fiveofsevin fiveofsevin is offline
fiveofsevin is starting off with a positive reputation.
Re:
Doing this
  #57
Old 05-07-2015, 01:49 AM
tasaro510 tasaro510 is offline
tasaro510 is starting off with a positive reputation.
Does anyone have a picture of the corrugated plastic headliner installed? I would live to see that!
  #58
Old 06-17-2015, 08:12 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
I used the 8x10 "Sanitary Panel" from Home Depot. These are used in industrial kitchens on the walls and is white plastic. It cost about $36 with tax and I don't have to worry about the glue coming loose. I cut it with a jigsaw.
  #59
Old 06-17-2015, 12:02 PM
Tank77's Avatar
Tank77 Tank77 is offline
Tank77 is starting off with a positive reputation.
Mine is missing the headliner completely.. What hardware did you use to hang it and where did you get them?
  #60
Old 06-17-2015, 12:04 PM
bkaul's Avatar
bkaul bkaul is offline
bkaul is gaining momentum as a positive member of FTE.
Hardware to hang it = the trim around it, plus that one screw in the middle.
Trim isn't reproduced - you'll have to find it in a junkyard if you don't have it. But if you've got trim and just no liner, then you're already in good shape. That's what holds it up.
Update on Benchwork steering conversion co425 1973 - 1979 F-100 & Larger F-Series Trucks 15 03-07-2017 02:19 PM
Betty turns oil burner co425 1973 - 1979 F-100 & Larger F-Series Trucks 1650 03-01-2017 06:09 AM
Dash Bezel silver trim how to co425 1973 - 1979 F-100 & Larger F-Series Trucks 54 06-27-2016 11:47 AM
70's roll bar upgrade co425 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-17-2015 07:05 AM
Mounting a Saginaw box on a highboy co425 1973 - 1979 F-100 & Larger F-Series Trucks 19 09-22-2014 02:09 PM
Tags
19731979, building, buy, cheap, f150, fabric, ford, hard, head, headliner, headliners, laredotx, liner, making, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
