Headliner on the cheap. - Page 2 - Ford Truck Enthusiasts Forums
Old 09-14-2011, 10:28 PM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
Looks awesome! Great job. I'm definitely going to doing this.
One question. Is the board stiff enough to not need the screw in the middle to help support it?
Old 09-14-2011, 10:43 PM
co425's Avatar
co425 co425 is online now
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Yes. I was going to use a piece of dual lock to hold up the middle but it is not needed. It is hard up against the center support.
Old 09-15-2011, 12:18 AM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Quote:
Originally Posted by supercabfreak View Post
how much more dificult could that be for a supercab...? my only problem is i dont have a old one to trace
Do you have the trim that would hold it in place? Lay it out like it is when installed (overlapped) and add 1/2" to 3/4" to the inside trace line.
Old 09-15-2011, 02:02 AM
sled250's Avatar
sled250 sled250 is offline
sled250 is starting off with a positive reputation.
That looks awesome. definately going this route for mine. cost effective is the name of the game, plus i think it looks better than the factory one. Awesosme job. ill drink to that one!!
Old 06-03-2012, 08:18 PM
400inatruck's Avatar
400inatruck 400inatruck is offline
400inatruck is new and has a neutral reputation at this point.
I know this thread is old, but I was looking for headliner alternatives. Thanks for the idea.
Old 06-03-2012, 09:41 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
How about coated hardboard like the kind used for bathrooms? Easy to clean and comes in pressed patterns like tiles.
Another material I spied were lightweight fiberglass sheeting used for backsplashes in restaurant kitchens. 'seemed to be flexible enough.
Old 06-03-2012, 11:17 PM
crsweet78's Avatar
crsweet78 crsweet78 is offline
crsweet78 is gaining momentum as a positive member of FTE.
Use Abs plastic. One sides smooth, one sides textured. Trace your old headliner on to the abs, score it with a razor blade and snap the excess off. Use the textured side as the side facing down. Probably the easiest way if your not looking to finish it off with anything.
Old 06-04-2012, 12:28 AM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
my truck is a giant piece of ***, but the original headliner is still up there and looking decent. decent being a relative term, in comparison to the rest of the truck.
Old 06-04-2012, 02:15 AM
gpence's Avatar
gpence gpence is offline
gpence is starting off with a positive reputation.
give's me a good idea on how to make all the bandana's I collected from the FORD tent's at the farm show's over the years usefull!
Old 06-23-2013, 11:37 PM
co425's Avatar
Its now June 23rd 2013 and that headliners still up no bubbles no peeling after almost two years of Northern California heat.
Old 06-23-2013, 11:42 PM
73 ford guy's Avatar
73 ford guy 73 ford guy is offline
73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.
I used a sheet of that corrugated plastic stuff. I picked up a 4x8 sheet for like $10 in black. Cut it using old headliner as guide and its mint. It looks really good
Link to a pic of what I'm talking about
http://cullytechnologies.com/demo/h2...l/p6010044.jpg
Old 06-24-2013, 07:25 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by co425 View Post
I disagree. The hard board is 4' x 8' and the vinyl is 54" wide x 10'. I think you could make that work as long as you have an old headliner to use as a pattern.
You need to buy 2 sheets of board because the Scab is like 54x56 or something like that. Basicly have to glue two sheets together.
If you dont have the original head liner, do you have the trim? You can lay out the trim and trace that then slowly cut it to fit. Another way is to measure the cab and cut the board larger and test fit/cut until you got it.
  #28
Old 09-21-2013, 02:27 PM
blue04.5's Avatar
blue04.5 blue04.5 is offline
blue04.5 is gaining momentum as a positive member of FTE.blue04.5 is gaining momentum as a positive member of FTE.
Thanks for this post. I am in the process of doing this now. I have the hardboard cut out and my wife is picking up the vinyl for me. Threw up some sound proofing in the roof yesterday to cut some of the tin can sound in the cab. Should clean up the interior nice.
  #29
Old 09-21-2013, 04:08 PM
co425's Avatar
Your welcome.
  #30
Old 09-21-2013, 06:02 PM
BTW iirc the super cab is 50x52 or 54, so its proving difficult to find a sheet of something I could use without doubling up.
Betty turns oil burner co425 1973 - 1979 F-100 & Larger F-Series Trucks 1635 Today 09:52 PM
Dash Bezel silver trim how to co425 1973 - 1979 F-100 & Larger F-Series Trucks 54 06-27-2016 12:47 PM
70's roll bar upgrade co425 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-17-2015 08:05 AM
L&L 460 swap headers 1967-79 F-100-350 78/79 Bronco 4X4 co425 Ford Truck Parts for Sale 2 03-07-2015 09:11 PM
The only snap on tool I will never buy co425 1973 - 1979 F-100 & Larger F-Series Trucks 7 08-07-2011 11:06 PM
Tags
19731979, building, buy, cheap, f150, fabric, ford, hard, head, headliner, headliners, laredotx, liner, making, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
