What do you get w/ Eddie Bauer?
Old 09-14-2011, 02:45 PM
wrenched's Avatar
wrenched
wrenched is offline
Just got a new-to-me 96 F150 4x4 SC Eddie Bauer. This replaced my '94 XL that got totalled. I was under the impression that the EB had all the bells and whistles, but apparently not. Such as with power door locks, I figured the EB had a keyless remote. But I tried the "switch ignition on/off 5 times in 10 seconds" routine to see if the PDL's would bump, but no-go. So maybe I got a "base" version EB? Oh well, at least now I don't have to lay over the seat to roll down the px window, which I like! So anyone know what comes as standard with EB trim, and what would be extra?
Old 09-14-2011, 03:33 PM
andym's Avatar
andym
andym is offline
EB is a trim package. Power locks, windows, etc. are all options. You can get a trim level with or without options - they are "optional".
EB comes with two-tone paint, badges, headliner, cloth bucket seats (at least in the Bronco they do, not sure about the F-150), wood burl trim, chrome around the wheel wells, etc.
A dealership brochure (sometimes found on ebay) will tell you for sure.
Old 09-14-2011, 10:49 PM
redlightning93's Avatar
redlightning93
redlightning93 is offline
Eddie Bauer trim included Two Tone Paint, Step Boards, EB Decaling and Aluminum "Porthole" Wheels. The interior included 40/20/40 Seat and Dash Trim with EB Badging. Options included a Light & Convenience Package and Captain Chairs in the Supercab version. All these items were upgrades to the XLT Trim
Your RKE System cannot be programmed through the ignition like the '97 on models. There is a grey two pin connector under the dash that has to be jumped to place the system in program mode. You can then program your remotes to operate the door locks.
Old 09-15-2011, 07:57 AM
wrenched's Avatar
wrenched
wrenched is offline
Thanks - I'll take a look around for the gray connector, and if I find it maybe I'll buy a remote (don't suppose there's remote start hidden away somewhere?). Are there additional instructions other than just jumpering the pins to getting a RKE programmed? My EB does not have running boards, but I can tell there's been some repainting so possibly they were damaged and removed by a PO.
Old 09-15-2011, 09:02 AM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
IIRC, The Eddie Bauer Edition trucks came with a complementary sports style bag or something like that........
Old 09-15-2011, 09:26 AM
wrenched's Avatar
wrenched
wrenched is offline
#!@%!! PO kept the sports bag!!! I knew they were holding out!
Old 09-15-2011, 01:17 PM
redlightning93
"Thanks - I'll take a look around for the gray connector, and if I find it maybe I'll buy a remote (don't suppose there's remote start hidden away somewhere?)."
The Remote should have these numbers on the back:
FCC ID GQ43VT4T
DOC 1470 K763
No remote start available from the factory on these trucks.
"Are there additional instructions other than just jumpering the pins to getting a RKE programmed?"
The connector should be taped to a wiring harness located somewhere behind the dash cubby hole at the drivers side. Once you locate it turn the ignition to the "run" position and jump the two pins together. Your locks should cycle indicating that the RKE system is in the progam mode. You then press one button on each remote you are programming and that should do it.
"My EB does not have running boards, but I can tell there's been some repainting so possibly they were damaged and removed by a PO."
A lot of these steps were damaged and not replaced and some owners just did not like them so they removed them entirely.
I will see if I can get a pic of the RKE Connector and send it to you.
Old 09-15-2011, 01:41 PM
subford's Avatar
subford
subford is online now
Here is what Ford said about Eddie Bauer.
Old 09-22-2011, 01:25 PM
wrenched's Avatar
wrenched
wrenched is offline
I haven't been able to locate the 2-pin connector. I did find a couple other gray connectors that are unconnected, mounted just below the ash tray. What would they be for?
What are these connectors for? | Flickr - Photo Sharing!
Old 09-22-2011, 02:11 PM
Flatbedbill's Avatar
Flatbedbill
Flatbedbill is offline
I know one is for the trailer brake control.
Old 09-22-2011, 02:41 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
Originally Posted by andym
EB comes with cloth bucket seats (at least in the Bronco they do, not sure about the F-150)
I have leather eddie bauer seats in my Bronco.
RI-Matt
1997-2006 Expedition & Navigator
06-19-2005 01:20 PM
teevans
05-30-2005 04:17 PM
91BroncoEB
1978 - 1996 Big Bronco
03-07-2004 02:50 AM
coastwatcher
02-23-2004 12:13 AM
1997'Exped
Appearance & Dress-Up
05-02-2003 09:15 AM
Quick Reply: What do you get w/ Eddie Bauer?
