Project: Tow Tool - Ford Truck Enthusiasts Forums
Project: Tow Tool
Old 09-14-2011, 10:28 AM
hadfield4wd hadfield4wd is online now
hadfield4wd is starting off with a positive reputation.
Project: Tow Tool
Tow Tool. Thatís what it is, a tool for towing.
So here it is in all its glory. 1985 Crew Cab Dually with 460 and 4 speed no OD. Pretty base truck. Itís got new seats, clutch, water pump, master cylinder. Following is the list of repairs. Iíve already bought/ordered most of the stuff I need. As far as the bed I donít think Iíll be able to find a 26 year old bed around so Iíll either make a flat bed or buy a utility bed.
List of repairs
Fuel
o Rebuild Carb
o Replace all soft lines
o Fuel Pump
o Remove tanks, clean and reinstall
Exhaust
o Headers
o Dual Exhaust-H pipe and mufflers
o Remove all EGR stuff
Under hood
o Battery
o Flush Rad
o Change oil
o Air filter
o Plugs
o Cap
o Rotor
Chassis
o Shocks
o Go over steering ends
o Go over brakes
o Go over all U-Joints
Tires Ė Used
New Windshield
Body
o Fix all rust
o Build flat bed
o Lights
o Mud flaps
Future Mods
o Bucket Seats
o Intake
o Cam
o Wheel covers
o A/C
Pretty sure thereís a big stinking engine under all that EGR crap. Itís all going away.
Old 09-14-2011, 10:29 AM
Rims are painted black with the new/used tires, I’ll be getting chrome domes for the lug nuts. I also have 2 spares I picked up. New Windshield. Fuel tanks are cleaned out. I had a hard time finding the pickup’s because apparently my truck is a mid year truck. They went to fuel injection in mid year and mines a carb. The FI pickups have a return line and an extra contact for 12v to the intank pump.
I have replaced all the fuel lines as well as the pump.
Took all the EGR stuff off.
Yep there is a motor under all that crap.
Rebuilt the carb.
Got the headers and installed the passenger side. When I took off the driver side manifold the previous owner had already replaced the gasket only to find he broke off 2 bolts in the head. I can’t get in with an angle drill so the head comes off.
I love these old trucks. I can really get into it.
Head off.
Old 09-14-2011, 10:30 AM
I got the exhaust welded up. Hedman headers into 2 Ĺ” tubes. Running to a 2 into 1 magnaflow knock off, big body muffler with a 3" outlet. Should be pretty free flowing. Sounds decent without being too loud. The stock muffler was pretty restrictive.
Got the carb tuned and running decently.
Running video.\/ \/
Once I get it up and down the road a couple times my carb genius friend is going to check to see what kind of rejetting I'll need.
The local O’Reilly’s manager found the rear fuel sender and the tank selector vavle. I’ll have it today or tomorrow. It’s got a bad ujoint so I have the rear shaft out. I’ll get the joint in then the shaft back in.
Just need to work on a bed, rear wiring and hitch.
Old 09-14-2011, 10:31 AM
Bed
Got the hitch on.
Left to do:
Stake pockets and steel "strap" for tieing down
1 more brace for the hitch area
Headache rack
1/8" on front and rear of the inside portion to sit the wood on and give it a place to screw it down
gas filler tubes
safety chain loops
mud flaps
stain and cut wood to fit
lights
paint
no it's not crooked. It's camera angle and the fact that the frame drops down lower in the front corner.
Old 09-14-2011, 10:32 AM
It was literally 100deg today so I was a little warm welding.
Stake pockets and rub rails done.
The fuel fillers are in.
I added the brace for the hitch area.
The 1/8” on the front and rear for bolting the wood down to is on as well.
Lights are on but not wired.
I had to make access for the fuel filler. I had no other way to do it that wouldn’t make the pump shut off. I started looking at other beds and they have the cutouts as well. So I don’t feel all that about it.
Done. Has an inspection sticker.
Tow tool - YouTube
Old 09-14-2011, 10:34 AM
I do have a question. My dual tanks are kinda screwy. When I turn off the truck the fuel siphons off the tank I was running into the other tank. So if I have the switch on the front it siphons to the rear and vice versa. It's a new switch and pickups.
Do I need some sort of check valve? Is this common and is there a fix.
Old 09-14-2011, 11:42 AM
Sw1tchfoot Sw1tchfoot is offline
Sw1tchfoot is gaining momentum as a positive member of FTE.Sw1tchfoot is gaining momentum as a positive member of FTE.
I have never heard of that happening. I have heard of the fuel returning to the wrong tank.. but not when sitting.
Other comments:
I can't tell if you did anything about those tubes coming out of the float bowls on the carb, but if I were you I would put some caps on them or run a hose from one to the other so they aren't open to the atmosphere.
Plus, since you have already did a lot of work; I don't know if you would mind doing more or not. Since you removed all your smog stuff, you might the information at the bottom of this page helpful. Classic Inlines Performance Parts - Duraspark Swap
Old 09-14-2011, 11:50 AM
Quote:
Yeah it's weird. It's only after I've run it, this gets the fuel going in a "siphon" effect. There are no return lines. So the switch just seems to act like a "T".
Other comments:
Yeah they are vented to the stock charcoal canister.
This is going to be an ongoing project. So thanks for the link. Eventually it'll get the interior replaced etc.
Old 09-14-2011, 01:26 PM
So I just found this. Think it would work?
3/8 Check Valve Diesel or Gas 10mm One Way Fuel Flow
Old 09-15-2011, 04:27 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
I suppose they would work.
Ford issued external check valves as a bandaid to a similar problem years ago.
There should be a return line from the fuel pump back to the switching valve. (at least there is on my truck)
Since you have a mechanical pump all switching is done at the valve and there are no check valves in the tanks.
I've never heard of fuel transfer while the engine is not running.
I'm sure a lot of our members who live in emissions mandated states would be interested in that pile of "stuff" in your driveway.
Consider offering it up in the 'Marketplace' section of the forum.
Having a few extra $ for parts or fuel in that beast is never a bad thing.
You seem to have done a really nice job with that rig so far.
Congratulations!
Old 09-15-2011, 07:53 AM
Congratulations!
No return line on this. Apparently it was added in '86.
That stuff in the driveway is already thrown in the garbage. It was in bad shape. The recirc stuff was rusted into the manifolds bad. The smog pumps were both seized up. etc.
Old 09-15-2011, 11:27 AM
Blue86's Avatar
Blue86 Blue86 is offline
Blue86 is starting off with a positive reputation.
You definitely got some work done on that. Very cool hauler.
Old 09-15-2011, 10:30 PM
Galendor's Avatar
Galendor Galendor is offline
Galendor has a good reputation on FTE.Galendor has a good reputation on FTE.Galendor has a good reputation on FTE.
Tow Tool is awesome and unique. Great job!
1989 F150 XLT Lariat hadfield4wd 1987 - 1996 F150 & Larger F-Series Trucks 102 Today 02:08 PM
Middle TN Picture Day tacson 1948 - 1956 F1, F100 & Larger F-Series Trucks 89 11-13-2012 10:51 PM
1986 F150 money pit / trail rig / SAS 4 link '88_F-150 Offroad & 4x4 27 08-27-2011 03:48 PM
F100 Supernats Pics tacson 1948 - 1956 F1, F100 & Larger F-Series Trucks 36 05-21-2011 10:45 PM
Rebuilding the Beast addixionz 1973 - 1979 F-100 & Larger F-Series Trucks 17 03-26-2009 08:57 PM
Tags
1980, 1982, bronco, carburetor, f150, filler, ford, gas, headache, inline, rack, tool, tow, truck, utility
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
