1986 F250 starting issue
Old 03-22-2016, 08:46 PM
redbayredneck's Avatar
redbayredneck
redbayredneck is offline
Was working on my truck yesterday (1986 F250 w/ EFI 302 and 4-speed manual) had my wife try to start it (I had just adjusted the timing and wanted to make sure that it hadn't moved while I was tightening up the distributor) and it attempted to start then the solenoid popped. Smoke came out of the solenoid, and now I have no lights in the dash and no power when I turn the key.(fuel pump doesn't cycle, no dash lights cycling on, nothing)
Could all this be caused by a bad solenoid? Or do I have other issues?
Old 03-23-2016, 03:52 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
I suspect you popped one (or more) or the fusible links attached to the fender relay.
Since the battery cable and all the power going to the cab use one lug of the relay as a junction, failure of the relay itself is not the problem.
Ryan Lewis
1999 to 2016 Super Duty
02-19-2018 12:03 AM
NicktheBrit
04-11-2014 01:44 PM
jawmarq
11-14-2012 05:12 PM
Frank Ruzicka
1997 - 2003 F150
08-10-2012 10:44 AM
Karma
33
03-04-2007 10:54 AM
Quick Reply: 1986 F250 starting issue
