Cooling Question - Page 2 - Ford Truck Enthusiasts Forums
Cooling Question
Old 09-15-2011, 01:41 PM
hxgaser hxgaser is offline
hxgaser is starting off with a positive reputation.
You noted that you have an electric fan. What temperature is that fan set to come on? Also is that fan big enough for your radiator? Also are you running a mechanical water pump or an electric? It would also be nice to know what motor you are running.
Old 09-15-2011, 10:08 PM
Showpanther's Avatar
Showpanther Showpanther is offline
Showpanther is starting off with a positive reputation.
My fan is on all of the time. I'm not sure what CFM the fan is. I am running a 350 engine with a mechanical water pump.
Old 09-16-2011, 04:04 PM
You said it is running 220 on a hot day. Is it idling or at higher RPM? Not always, but a lot of times, if it is overheating at higher RPM, then you maybe dealing with the lean mixture issue. Overheating on idle/low speed relates to the circulation/cooling area issue.
BTW, Here is a copy of the edelbrock owner's guide.
Owner's manual
If your numbers were ground off, then the only way to tell the carb size is to pull the main jets and the metering rod and compare it to the chart.
I would go about it in the following steps.
1. Change the thermostat back to about 180. Install it the correct direction.
2. Check the size of the fan. It should pretty much cover the radiator at least in one direction. If you have a shroud, then the fan should be set away from the radiator and the shroud should funnel the air to the fan. Although not optimal, if you don't have a shroud, then just place the fan on the surface of the radiator.
3. Check the temp. If it is overheating at idle/slow speed, then I would suspect the water pump giving out. Also I have seen cases where the radiator hoses buckle. Check that too. If it overheats only at higher speed only, then I would suspect the lean mixture.
Thermostat is designed to keep the motor at certain temperature. If stuck open, it will cool the motor which it is not efficient. If it is stuck closed, then obviously you will have an overheating issue.
As for the comment about coolant needing enough time in the radiator to cool, I claim BS. Cooling system is a thermodynamic system. As long as there is a continuous run for the coolant to travel, (as in no blockage) faster moving coolant will cool the system faster than a slow moving coolant. Why do you think that they make high performance water pump with higher flow?
Sounds like you have a super duper radiator. So I wouldn't worry about that. Also you may want to think about installing a fan control switch. There are various options that give you control over when to kick in. Obviously it wouldn't do anything for your cooling issue, but it is more efficient with the fan control than to run the fan all day long.
Old 09-20-2011, 07:15 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
Gasser,why do you think it is more efficient to not run the fan all the time? Are you concerned with the need for the alternator to make electricity continuely? If so, I think that is a small price to pay to be sure that your fan is functional before you leave the house and then overheat two miles down the road. For a critical system like the electric fan, I like the reassurance of hearing the fan come on when I first turn the key to be sure that no fuse or wiring issues exist. My buddy had a smoked wire and got stranded about three miles from his house when the temp gauge peaked and the rad went peepee all over the pavement. JMHO, Jag
Old 09-22-2011, 05:11 PM
Quote:
Yeah I agree with your comment, but I am also one of those guys who is **** about being efficient. As I said on the post, "it would not do anything to solve his issue." But generally speaking, you don't need electric fan running all the time.
Lifter hammers when engine warms up ecidemon FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 01-10-2011 05:27 PM
Stator On Alternator Not Putting Out Volts jim4 1973 - 1979 F-100 & Larger F-Series Trucks 15 12-26-2008 04:03 PM
Increased Engine Temperature / Headers advice herkdriver 1973 - 1979 F-100 & Larger F-Series Trucks 20 09-12-2002 09:22 PM
72 F100 Motor mounts for 351W 64ford 1967 - 1972 F-100 & Larger F-Series Trucks 5 06-18-2001 12:50 PM
Radiator cgl 1987 - 1996 F150 & Larger F-Series Trucks 11 02-04-2001 09:50 PM
Tags
292, cooling, engines, flathead, ford, laser, measuring, temperature, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
