heads
Old 09-13-2011, 07:50 PM
deve's Avatar
deve
deve is offline
heads
what is the difference from the gt40 and gt40p heads?
Old 09-13-2011, 09:10 PM
ilovemy60ford's Avatar
ilovemy60ford
ilovemy60ford is offline
Somebody correct me if I'm wrong - but I believe the GT40P heads require intake and exhaust components specific to that head, while GT40's share the same intake / exhaust configuration with everything else under the sun.
I hear they flow better than the average stock head though.
Old 09-13-2011, 11:21 PM
Beatertruck's Avatar
Beatertruck
Beatertruck is offline
A standard GT-40 was introduced on the 93 cobra and is a decent little head for a mild bolt on application.
The GT-40P are basically the same head but with an angled plug design. They are a pain in the @#$ because of that issue. They are V8 ford explorer heads.
Old 09-13-2011, 11:30 PM
Conanski's Avatar
Conanski
Conanski is offline
GT40 heads have 1.84/1.54" valves and larger ports for about 20% better flow than E7TEs, but otherwise look and fit the same as stock heads. GTP heads have 1.84/1.46" valves but have better port designs that flow about 10% better than GT40s, but they also have a radical spark plug angle that makes fitting headers a problem.
Old 09-14-2011, 07:20 AM
deve's Avatar
deve
deve is offline
so where would you buy headers for the gt40p. i just bought a 351 for my 89 f150 and planned on improving the heads a little so i figured the gt heads were the way to go
Old 09-14-2011, 08:59 AM
Conanski's Avatar
Conanski
Conanski is offline
Simply avoid GTP heads if you can, but if you did end up with a set standard longtubes or unequal length shorties will work with a little customization... i.e: a few header tubes may need to be clearanced for the plugs.
Old 09-14-2011, 10:11 AM
deve's Avatar
deve
deve is offline
so what would you do to the head try to find a gt40 or just use stock
Old 09-14-2011, 07:19 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
I'd keep the stock heads until I could find a deal on a pair of aluminum heads. I see them on cl for ~$500 all the time.
Old 09-15-2011, 08:53 AM
Conanski's Avatar
Conanski
Conanski is offline
Yes.. this is exactly why it's not worth spending any more than a few hundred dollars on stock heads, because even the worst of the aftermarket heads have more performance potential than GT40s.
johnsf
09-21-2008 09:11 PM
84bronco25.0
06-07-2008 04:31 PM
LedheadELH
12-10-2006 08:30 AM
lilpro
09-28-2006 04:25 PM
Special ' 67
18
12-02-2003 09:29 PM
Quick Reply: heads
