Single or Dual steering stabilizer???
The dual steering stablizer kits at TopgunCustomz.com place the stabilizers directly "in front of" the tie rod assembly for both the 1999-2004 and 2005-2010 Super Duties. I noticed that some pics in this tread have them placed 2 inches "below" the tie rod assembly, which are more likely to be damaged while off-roading.
1999-2004 Super Duties:
MarketplaceAdvisor Image Hosting: Full Sized View
2005-2007 Super Duties:
I put a dual setup on a 20 year old Chevy 5 years ago... original pump is still going strong. If anything, it probably helps the rest of the front end steering components last longer.
As someone said above though, if you're got a bad shimmy, this is really only masking the problem. You need to make sure everything on the front end is straight and true before adding these.
my truck drove perfectly straight and no shimmy at all...but when I hit a bump (pothole), the damn thing went crazy
put the stabilizers on and that instantly went away. You don't have to have any worn components to experience the death wobble. It's just something that happens with a live axle truck...especially a HD one with larger tires
Kyle 4X4 4life
02-03-2011 09:42 PM
