My project is finally starting to get somewhere. Well...I'm not sure where, but somewhere. Its been together and in pieces several time deciding wherer I wanna go with it. Its time to address my soggy tranny situation. While doing this I decided to chuck the boat anchor of a 203 out for the more appropriate 205. I do have a few questions though. What all mounts do I need to change? I know the 205 has a side mount that bolts to the frame but what else has to change?
Is your truck an F150 or F250, and if it's an F250 is it a hiboy or not? And is it manual or auto? I don't think you clarified. I've not done the swap, but you should at least check into it if you have a half ton or a loboy. I think the transition housing and output shaft of the trans are different lengths between the two transfer cases. I thought there was a thread about this in the last week or so. Do a search.
Its a 150 with a c6. I did some searching but didn't find everything. Some say the crossmembers the same and some say its different. And the long or shory adapter issue
