'11 F250 Suspension Help?
It seems that the springs on my '11 F250 are softer (for ride quality?) than either my '93 or '01.
My 3-horse trailer (GW ~7000#) causes the rear end to sag in a way that neither previous truck did. I have a 6-horse gooseneck that rides closer to level, but again not like it did on my '93.
We haul horses quite a bit through the summer, less so in the winter. I want to beef-up the suspension this winter. A few folks told me "air bags". A local parts/trailer shop talked up "Timbrens".
I'd appreciate opinions. Thanks.
From the info I've read on the Timbrens is that they should contact at about 1/2" drop and are progressive from there. They also preserve the unloaded ride quality.
They are attractive to me as I should be able to easily install them myself.
Any reco's for airbag brand?
Flash forward 25 years to 2010 and a '07 3/4 ton Chev. Once installed on this truck, the Timbrens were only about 3/4" from the bump stops. Every little manhole, bridge abutement, expansion joint, etc., the rear end would kick you in the seat of the pants after the initial bump. Very uncomfortable empty ride. Hated it! Once the Timbrens were loaded, no issues. Very capable product. Again, very ez install.
I had a set of air bags on an '05 Chevy that were on it when I bought it. They were nice. Don't know the brand. Had a valve stem fitting on each corner of the rear bumper to fill them. A little crude, but functional. If I were going for a suspension supplement I would go air bags. Lot's of options out there.
Google Air Ride Suspensions or Firestone Air Bags.
Good luck.
Epiccowlick did a neat video install of an airbag system.
If you wish to level the truck under load and enjoy a smooth ride unloaded, "Trucks" on Spike TV channel just had an episode on installing the Firestone R4Tech system:
Firestones R4Tech is a patented hybrid air over leaf suspension that provides the ride quality of a full-air suspension, the axle control of a leaf spring and the ease of installation of a standard leaf spring and Ride-Rite Kit.
I looked it up 'cause I thought i'd be around $5K, but it's under $2200. The nice part (besides the smooth ride) is that it's all automatic with ride height sensor controlling the pressure to the bags for your various loads - and it's all bolt-on!
Anyone with thoughts or experience with this system?
corey fletcher
06-07-2010 05:55 AM
