Injector cups
Injector cups
Alright I'm going to replace the one injector cup that had a water/fuel mix spraying out when I was purging the cylinders after doing all of them hoping this is my problem with fuel still being in the coolant. If your just doing one( the back passenger one) is it ok to just remove the one injector and glow plug and follow the same procedure?
Was it spraying from the glow plug hole?..
The only other ways for water to be in the cylinder are head gasket or a crack in the cylinder . If you had a crack in the cyl wall , there would have been water blowing out of the degass bottle from the pressure . Head gasket usually makes a lot of steam in the morning at start up , or if its really bad ,the motor will hydro lock. You can also do a test called a cylinder leak down .. It will tell you where anything is leaking
Leak-down tester - Wikipedia, the free encyclopedia
try getting a cooling system tester , see if it holds pressure first . Then if not , look for the leak ...
Need more info.
If the sleeve had been previously replaced and you now see coolant spit out the cylinder, then that sleeve was not re-installed propely and needs to be done again.
If that sleeve was not previously replaced, I don't think it's your problem.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
