Mustang gas tank dimensions? - Ford Truck Enthusiasts Forums
Old 09-13-2011, 01:19 PM
Drewski 2's Avatar
Drewski 2 Drewski 2 is offline
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
After deciding to purchase a new gas tank for my 55, I've run into some confusing information regarding dimensions of the 69-70 Mustang tanks. Are they 30 1/4" wide, 32 5/8", or 35" wide like some of the sites indicate for their tanks.
Would someone who actually has one of these tanks mind telling me what they really are. I'm not sure why the dimensions vary from vendor to vendor.
Thanks
Old 09-13-2011, 01:50 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
Drew,
Just went outside and measured my factory stock 1970 mustang tank for you; outside flange to outside flange 32 3/4" , actual tank width is 30".
Hope this helps.
Old 09-13-2011, 01:51 PM
By the way '70 is 22 gal and '69 is 20 gal, if you did not know.
Old 09-13-2011, 01:56 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Thanks
some measure to the edge of the flange, and some just the tank body itself
Sam
Old 09-13-2011, 02:02 PM
Drewski 2's Avatar
Quote:
Originally Posted by truckeemtnfords View Post
Drew,
Hope this helps.
Thanks, that helps a lot.
Old 09-13-2011, 03:58 PM
ben73058's Avatar
ben73058 ben73058 is online now
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Drew,
There are plenty of installation pics on the mustang tank installation. Here is how my '70 tank sits out back. (I haven't installed the bed floor yet so I haven't tackled the finish out).
Ben in Austin
Old 09-13-2011, 04:57 PM
JBjorgaard's Avatar
JBjorgaard JBjorgaard is offline
JBjorgaard is starting off with a positive reputation.
Quote:
Originally Posted by ben73058 View Post
Hey Drew,
Ben in Austin
Got enough steel to carry a small military tank in the bed back there. It is certainly going to be stronger than stock!
Old 09-13-2011, 05:56 PM
ben73058's Avatar
Hey JB,
My bed structure was all rotted out underneath - I could have ordered a replacement bed but I really wanted the Bed & Cab to be original to 1950 so we did a little re-engineering to stiffen it up a bit. Needed a big piece of metal between the rear of the truck & the tank as well as we aren't running any bumpers. I've seen some guys on here put armor in over the top of the tank as well.
Ben
Old 09-13-2011, 06:23 PM
JBjorgaard's Avatar
Ben,
I figured as much, was just commenting on how it looked like it would be rather sturdy...not at all a bad thing, meant as a compliment.
Old 09-13-2011, 07:04 PM
jniolon's Avatar
jniolon jniolon is offline
jniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud of
DREW,
did you look here
INSTALLING A MID-60's Mustang Tank in a '53 F-100 truck
hope it helps
j
Old 09-13-2011, 09:04 PM
Wayne S Wayne S is offline
Wayne S is starting off with a positive reputation.
Quote:
Originally Posted by jniolon View Post
DREW,
did you look here
hope it helps
j
I used this info to install a 70 Mustang tank in my 48.
Made it super easy to install. Thanks John.
Old 09-14-2011, 06:24 AM
Drewski 2's Avatar
DREW,
did you look here
hope it helps
j
John, I found your site before I ever even knew about FTE. The thing that had me confused were all these different dimensions that the vendors were giving.
If I hadn't taken so long on this build, the tank I already had installed would have been ok. I had a 1971 Maverick tank already installed, which used straps to hold it in. It was a good fit, but when I realized that you couldn't buy a reproduction tank, I got to thinking (bad idea, I know) that if I ever had a problem with the tank I wouldn't be able to find a new replacement. Back in the 80's those tanks were not hard to find.
The Maverick tank had some damage on the bottom that I thought might eventually cause some problems
Old 09-14-2011, 08:21 AM
jniolon's Avatar
I'd be surprised that you couldn't find a repop tank from some of the mustang after market folks... something odd about that one ??
j
Old 09-14-2011, 03:45 PM
J,
Drew was saying he could not find the replacement Maverick tank, not the Mustang tank.
Old 01-08-2015, 11:42 PM
pieman314's Avatar
pieman314 pieman314 is offline
pieman314 is starting off with a positive reputation.
mustang tank dimensions
Are you planning on running an electric pump, or the mechanical type ? And would you be concerned with slosh when you hit the accelerator hard with the feed in the front of the tank. It seems to me that the force would throw the fuel away from the flow.
Bed Wood Dimensions ? Don Vito 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 06-27-2016 01:34 PM
Gas Tank Dimensions FJones8668 1957 - 1960 F100 & Larger F-Series Trucks 0 12-28-2015 04:50 PM
Custom Gas Tank Dimensions? BigBlueCat 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-14-2015 08:07 AM
1965 f100 fuel tank mattb 1973 - 1979 F-100 & Larger F-Series Trucks 19 11-03-2014 02:20 PM
Mustang tank swap rews2 1967 - 1972 F-100 & Larger F-Series Trucks 10 08-09-2014 07:54 PM
Tags
1966, 1967, 1972, 70, dimension, dimensions, econoline, f100, gas, measurements, mustang, ranchero, ranger, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
