1984 Ford E350 Fuel Problem 460 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 09-13-2011, 12:09 PM
Kingfish9 Kingfish9 is offline
Kingfish9 is starting off with a positive reputation.
This is a 460 w/Holley 4B carb. Duel Tanks. Fuel lines go from carb directly back to tank selector on rail behind driver side and then to each tank. I see no mechanical fuel pump. Checked Inertia Switch-power is working. Vehicle has been sitting but i have been starting every week. I am not hearing any energizing of pumps when the ignition is on or cranking. I cannot find any fuse box under hood, only under dash. All fuses under dash check out good. Replaced both Fuel Relays[Power up (EEC) and Fuel Relay(green) on driver side fender under hood. Tank selector switch under dash panel indicates fuel in both tanks(it moves when the toggle switch is changed from tank #1 to #2).There is one small 3Amp fuse at the bottom right of the fuse panel that does not have any power even with a new fuse, key on or off. I'm not sure what that fuse is for. I checked all the tank selector wires where they plug into selector, with the ignition key on, and no power is indicated with the testlight on any of the contacts that plug into the selector. No power to tank selector wires during cranking either. Is there a 5 pin Fuel Tank Select Relay ? If so, where is it located ? Both tanks have fuel. Any suggestions ? <!-- google_ad_section_end --><!-- / message -->
Old 09-13-2011, 09:54 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
For testing the system you need to jumper out the oil pressure switch at the back top center of the engine. Then turn on the key and you can check every thing without cranking the engine.
You need to do all of the power testing with a test light and not a meter.
Here is a wiring diagram:
Old 09-13-2011, 11:06 PM
Thanks Bill. Can you give me a walk-thru on the testing? How do I "jumper out" the oil pressure switch ? Give me some details on checking out everything with the testlight. I need some step by step help as the electrical troubleshooting is a bit of a mystery to me.
Order of testing would be helpful too.
Old 09-14-2011, 07:48 AM
subford's Avatar
You have no EEC relay. Only the 5 pin Fuel Tank Select Relay and the Fuel pump cut-off relay.
To jump the oil pressure switch do it as in the photo below.
First you need to locate all of the items in the diagram above.
Most are in the photos below.
Maybe it would be better if you emailed me your email address and better yet if you would email me your phone number and when to call you.
My email address is at the bottom of this post.
Oil pressure switch jumped:
Tank selector valve/relay:
Fuel system diagram:
The relays:
Old 04-02-2012, 12:34 AM
xbjbx xbjbx is offline
xbjbx is starting off with a positive reputation.
Well, thought I had posted a reply .. but nothing here.
So, thanks for the info again!
Now, how is all of these effected with an auxiliary battery ... (and a generator )?
Jeff
Old 04-02-2012, 09:32 AM
subford's Avatar
Quote:
The auxiliary battery and the generator are for use with the coach and not the chassis.
The engine charging system does charge the coach battery but not the other way around.
Some do have an jump switch that you can push if the chassis battery is down to get your engine started.
The auxiliary battery and the generator have nothing to do with the fuel system.
87 F250 460 fuel tank selector relay location? jumbofordman 1987 - 1996 F150 & Larger F-Series Trucks 2 02-02-2015 06:15 PM
1987 F250 Hot Fueling tideman7 1987 - 1996 F150 & Larger F-Series Trucks 25 01-29-2013 02:02 PM
Fuel Tank Selector Switch 86 F250 7.5 Hydropower Luke 1987 - 1996 F150 & Larger F-Series Trucks 3 01-04-2012 05:47 PM
No start, fuel problem, no power to pump Powerstroke-7.3 1987 - 1996 F150 & Larger F-Series Trucks 13 12-29-2009 03:45 PM
1990 F-700 fuel problems Duksrule 1987 - 1996 F150 & Larger F-Series Trucks 7 07-01-2009 11:03 AM
Tags
1984, 2000, 460, diagram, duel, econoline, expedition, ford, fuel, oil, pressure, rv, sensor, tank, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
