I am looking for info on this upgrade and not really finding it in the tech folder. Slowly doing upgrades to this truck. Coolant filter, scan gauge 11, I now want to put this spring in. How difficult is it? Where is it? I also am going to do a coolant flush as soon as I get the thermostat housing o ring from my dealer (not normally stocked??) however i am somewhat concerned about the VC 9 flush. What are the chances of CAUSING problems with this VC 9. Is the VC 9 a dealer product only? is there a similar product available after market thats adequate. Thanks
I got my spring kit from International, pn 1854267c94....~$37. This is the kit that does not have the cover included, just the necessary gaskets, o-rings, and the blue spring. I haven't put mine in yet, but I will do it when I change the fuel filters before winter.
If I recall, you pull the filer to empty the bowl of fuel so you don't get a diesel bath. The housing is on the driver's side of the filter bowl (outside). Drain a little coolant too so you can either push or remove the top rad. hose. It's a little in the way of one of the bolts.
I did mine yesterday. Pretty easy and the kit had a small diagram to show where some of the o-rings go. T25 torx for the cover, 17m and 18mm for the fuel lines...there's a banjo bolt on the back of the fuel bowl that I had to use a crescent wrench on as I didn't a large enough wrench for.
***EDIT***
The cover has T27 bolts...I used T25 and they worked, but not the right size.
