Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-13-2011, 02:31 AM
Narked Narked is offline
Garage is empty, add now
Narked is starting off with a positive reputation.
1974 ford f250 big block 460 died..pleae help!
Hey I just traded my 2001 Dodge Ram Crewcab 4x4 for a 1974 f-250 camper special 4x4 Beast! Has super Duty 4 wheel disc brakes,axles, etc. Dana 60 high pinion, sterling rear brand new locker in rear and truetrac in front. 44in boggers,red neck brand ram steering ,12in suspension lift, fresh rebuilt c6 with bigger stall, hooker headers, brand new exhaust, motor was said to be rebuilt a year and a half ago with just over 400miles on it, edelbrock 750 dbl pumper, torker intake,roller rockers, cam (unknown atm) New huge racing radiator,Mallory Dist. lots of recent receipts.Theres more but my problem is on ride home after picking it up it all of a sudden just died. Thought it was fuel added gas, splashed a bit in the carb. Engine cranked but no fire. Couldn't believe my luck, after I test drove it for a while the day before and drove it maybe 40 miles and this happened. Oil pressure was good, i think it was constantly around 60 or so, temp was at 170ish. I'm thinking maybe its a spark issue but haven't had time to look. took 5 hours to get a tow truck big enough for the truck. Need help as I am new to fords, and i just got the truck after trading my great running dodge. Didn't even get to drive it home and i feel like i got screwed here. Guy i got it from doesn't know whats wrong and denies anything was up before. I live in Riverside CA 92504 area if anyone can help me out! Please help me out if you can. u can text or call me at: --------------------nine-five-one-836-19eight7
(update 9-12-2001)
I just put a new coil in, old one seemed to have a weak spark. Truck still hasnt started yet. I believe its HEI now no longer points. Should i go for a mallory or msd ignition box to try to bypass my problems? the wires look so so, Im think of swapping to new but i doubt that is why the truck died. Haven't checked plugs yet but again doubt that is why it went from running fine to dieing. The numbers on the dist tell me its a newer HEI style. Could it be that the resister is the problem or the module? Again im not a pro at all when it comes to electrical trouble shooting. heres the pics:
  #2 (permalink)
Old 09-13-2011, 02:32 AM
I plan on losing the blocks soon in the rear and go for a flipped shackle. I was told i can get one from a chevy that will work at any junk yard.
  #3 (permalink)
Old 09-15-2011, 04:01 PM
NW 150's Avatar
NW 150 NW 150 is offline
1975 Ford F-100
My Garage
NW 150 is starting off with a positive reputation.
Instead of buying/going to buy a bunch of new parts, try and find out what's actually wrong in the first place? Is there spark at the plugs?
__________________
Quote:
Witty73: Thats not something you hear out of a 79 F 350 owner often...."dang, this thing sits too high!"
Open Headers, Flowmaster Super 10 Cruise,Flowmaster Super 10 Idle
  #4 (permalink)
Old 09-15-2011, 04:22 PM
Beechkid Beechkid is offline
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
It sounds as if the HEI module has died. IMHO, I would swap out to a set of points & see if it will run
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
Tags
1974, 1974fordf250ignitioncoilresistance, 460, big, block, build, camper, died, dies, f250, ford, mpg, ranger, special, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
